We recently (a couple of months ago) had a replacement Hub fitted by an engineer as the previous one stopped working.
Since then our Wi-Fi has been terrible.
The connection drops for no apparent reason and the speed really slows down, sometimes our devices are connected to the Wi-Fi but report there is no connection to the internet.
We use it in router mode and both 2.4Ghz and 5Ghz channels are enabled.
I've repeatedly run the broadband test on the main Virgin Media site and it always says
Looks like you’re having trouble connecting to the Hub
We can’t find any faults with the connection coming into your home, so we’ve got some tips for you to try.
The tips that are offered don't help at all.
I'm sitting 3m away from the hub, direct line of site, nothing in-between and it's already dropped connection 3 times today. Sometimes rebooting the hub clears it for a while, but the problems always come back.
Working from home and taking calls is getting to be a real pain now.
I don't know if this helps, I don't think it looks as bad as other peoples i've seen posted.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3b8fd37979530c6d0859ce21a5e53ebf48f88fe8-08-06-2022
I'm guessing either our new hub isn't working properly or there's a problem with the signal coming into it again (we've had that in the past).
Please could someone have a look at this and let me know if there is anything that could fix the issue.
