joshieeee
Packet loss
I'm getting bad packet loss (15% plus) in OX4 1. I've downloaded a monitoring tool to verify it.
I rang VM and they suggested sending out a new router (I've got a SuperHub 3 in modem mode - with Google Wifi mesh). My understanding is that probably won't help.
What should I do?
Josh
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Packet loss
Please post a 'Live Link' to your BQM on here.
joshieeee
Re: Packet loss
So I started this one yesterday:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/eaabb938d127ce6000b0aa23c49308f42f2c10d7
Thanks for your help!
joshieeee
Re: Packet loss
It looks like something might be blocking it. I've made some changes that might help.
