antwigan
  • 37
Packet loss
Hi. Could this be causing my packet loss in games? High download but surely the upload should be better. I've only had this problem since work was carried out in my area about a week ago.
Download 369mb Upload 11mb
10126905561
antwigan
  • 37
Re: Packet loss
Cable Modem Status Item Status Comments
451000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
Downstream bonded channels Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1451000000938256 qam40
22670000009.940256 qam17
32750000009.940256 qam18
42830000009.940256 qam19
52910000009.640256 qam20
62990000009.640256 qam21
73070000009.540256 qam22
83150000009.540256 qam23
93230000009.638256 qam24
103310000009.640256 qam25
113390000009.338256 qam26
123470000009.438256 qam27
133550000009.540256 qam28
143630000009.538256 qam29
153710000009.138256 qam30
16379000000938256 qam31
173870000008.540256 qam32
183950000008.840256 qam33
194030000008.840256 qam34
204110000009.140256 qam35
21419000000938256 qam36
224270000009.340256 qam37
234350000009.540256 qam38
244430000009.440256 qam39
1Locked38.9650
2Locked40.31610
3Locked40.91140
4Locked40.31130
5Locked40.91660
6Locked40.31210
7Locked40.31010
8Locked40.31160
9Locked38.9930
10Locked40.3680
11Locked38.910114
12Locked38.9840
13Locked40.3990
14Locked38.9950
15Locked38.91050
16Locked38.61010
17Locked40.31810
18Locked40.3890
19Locked40.31070
20Locked40.3830
21Locked38.91670
22Locked40.3600
23Locked40.3560
24Locked40.31070
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030000038.7512064 qam1
23940000039.8512064 qam4
34620000039.3512064 qam3
45370000038.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
2ATDMA0020
3ATDMA0010
4ATDMA0000
antwigan
  • 37
Re: Packet loss
22/09/2020 14:22:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 12:53:28ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 09:17:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 17:23:31noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 17:23:31ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 17:04:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 15:54:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 15:54:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 15:44:0ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 15:06:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 15:06:12ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 14:58:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 14:31:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 14:31:15ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 14:20:29ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 13:41:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 13:41:12ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 13:34:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 13:08:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 13:08:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Chris_W1
  • 4.06K
  • 185
  • 255
Re: Packet loss
Hi antwigan, I will send you a private message to look at the account. Chris
