Packet loss issue - ongoing for months [started Jan 2023 under fault no F010403749]
skyuser
Hey,
Hoping someone from  Virgin media can look into my issue please?
I have had difficulties with packet loss for going on a few months. Started back in  Jan 2023 under fault no F010403749 and went away for a while..but has returned and does not appear to be solved/solvable.
The automated 0800 faults line has said the same 'area issue, some faults take longer etc etc'
The BQM graph is a real mess, the solid red parts are power off/restarts after I've checked/rechecked and tightened all connections.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1401b4501efff9e57c01c7ce2c5b38a5551d1ded
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/1401b4501efff9e57c01c7ce2c5b38a5551d1ded]My Broadband Ping[/url]
 Is there an ETA for for the fix? Can an engineer check locally? Whilst this affects streaming, gaming, web pages  etc as it's not TLOS so likely no compensation for months of issues.
However, I would like this resolved, thanks
62 REPLIES 62
skyuser
skyuser
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
28
354750000
3.099998
38.983261
QAM256
28
1
138750000
5.300003
40.366287
QAM256
1
2
146750000
5.500000
40.366287
QAM256
2
3
154750000
5.900002
40.946209
QAM256
3
4
162750000
5.599998
40.366287
QAM256
4
5
170750000
5.500000
40.366287
QAM256
5
6
178750000
5.300003
40.366287
QAM256
6
7
186750000
5.300003
40.366287
QAM256
7
8
194750000
5.300003
40.366287
QAM256
8
9
202750000
5.199997
40.366287
QAM256
9
10
210750000
5.099998
40.366287
QAM256
10
11
218750000
5.099998
40.366287
QAM256
11
12
226750000
5.000000
40.366287
QAM256
12
13
234750000
4.800003
40.366287
QAM256
13
14
242750000
4.599998
40.366287
QAM256
14
15
250750000
4.500000
38.983261
QAM256
15
16
258750000
4.300003
38.983261
QAM256
16
17
266750000
3.599998
38.605377
QAM256
17
18
274750000
3.200001
38.983261
QAM256
18
19
282750000
3.700001
38.983261
QAM256
19
20
290750000
3.900002
38.605377
QAM256
20
21
298750000
4.599998
38.983261
QAM256
21
22
306750000
4.199997
38.983261
QAM256
22
23
314750000
3.700001
38.983261
QAM256
23
24
322750000
2.900002
38.605377
QAM256
24
25
330750000
2.599998
38.605377
QAM256
25
26
338750000
3.099998
38.605377
QAM256
26
27
346750000
3.299999
38.983261
QAM256
27
29
362750000
3.500000
38.983261
QAM256
29
30
370750000
3.700001
38.983261
QAM256
30
31
378750000
3.599998
38.983261
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
28
Locked
38.983261
0
0
1
Locked
40.366287
0
0
2
Locked
40.366287
0
0
3
Locked
40.946209
0
0
4
Locked
40.366287
0
0
5
Locked
40.366287
0
0
6
Locked
40.366287
0
0
7
Locked
40.366287
0
0
8
Locked
40.366287
0
0
9
Locked
40.366287
0
0
10
Locked
40.366287
0
0
11
Locked
40.366287
0
0
12
Locked
40.366287
0
0
13
Locked
40.366287
0
0
14
Locked
40.366287
0
0
15
Locked
38.983261
0
0
16
Locked
38.983261
0
0
17
Locked
38.605377
0
0
18
Locked
38.983261
0
0
19
Locked
38.983261
0
0
20
Locked
38.605377
0
0
21
Locked
38.983261
0
0
22
Locked
38.983261
0
0
23
Locked
38.983261
0
0
24
Locked
38.605377
0
0
25
Locked
38.605377
0
0
26
Locked
38.605377
0
0
27
Locked
38.983261
0
0
29
Locked
38.983261
0
0
30
Locked
38.983261
0
0
31
Locked
38.983261
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
94
4K
1800
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
41
5.6
258321347
0
skyuser
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
34.270599
5120 KSym/sec
64QAM
3
2
23600000
35.520599
5120 KSym/sec
64QAM
6
3
32600000
35.520599
5120 KSym/sec
64QAM
5
4
39400000
35.020599
5120 KSym/sec
64QAM
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_ATDMA
0
0
0
0
2
US_TYPE_ATDMA
0
0
0
0
3
US_TYPE_ATDMA
0
0
0
0
4
US_TYPE_ATDMA
0
0
0
0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
54k;fg87dsfd;kfoA,.iyewrkldJK
SFID
6064
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
6063
Max Traffic Rate
110000274
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Hi @skyuser
I am sorry to hear you're still having issues. The ticket number you posted in the subject of your post, F010403749, that was closed as fixed as of January 31st.
I have done a system check today and you are affected by an SNR issue (signal to noise ratio). Fault number is F010484200 and the estimated fix date is May 29th.
Please monitor the connection after this date and let us know if any issues, we'll be happy to help.
Best wishes.
John_GS
skyuser
Thanks for looking into this for me John.
I'll keep an eye on it and check in after the 29th to see if it still persists or  if there is another update/ERT
cheers
Was this a fault with the cabinet or at the front door ?
I have something similar but it is really random and only really noticeable when gaming. Mostly Rocket League or World of Warcraft.
Any tips to show any data ? I get it directly connected (Ethernet) to the Virgin Hub.
Hi John_GS,
Can you tell me if I am suffering the same issue as skyuser as I have been unable to game recently due to the upload speed being dire.
ironically, I keep reading about Virgin upgrading the upload speed.
Personally, I have been with Virgin for years and in their defence have had very few issues over the years. When there was an issue it was resolved quickly, my issue is with their pricing and once my contract ends in a few months will be moving to another ISP providing double the speed I have now at a lower price.
I really don’t understand why companies keep ramping up charges when if the price was kept lower they would retain customers and get even more new subscribers for having a competitive price, but no greed is boss for businesses.
This is what i see, following SKyuser's guidance on how to measure the Latency and Packet Loss. This visually shows what I have been epxeriencing for months now. I have both SKY and VM at home here, I never see these issues with the SKY service. Currently on hold with VM customer support, who are having a tough time understanding my issue is not speed related.
I will also do the same data capture on the Sky side to see what is normal/comparable.
VM - Your Broadband and VOIP services are very poor.
Just spent 45 mins on the call with CS - including transfer to Tier 2. They say there is no problem at their end !
So we monitor for 24 Hours and then see what happens next. From a user perspective, browsing, voice and gaming is affected and noticeable by me.
