inf
  • 20
Packet loss for the past four days
I had severe packet loss before, and it magically disappeared after a couple of months. Unfortunately, it has now returned with a vengence. I can reboot the HUB4, which helps for a few hours, but the packet loss always reappears. The effect on my video calls is catastrophic.
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Sat 05/12/2020 23:22:073No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 08/12/2020 02:19:094DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 08/12/2020 02:19:096DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tags (3)
inf
  • 20
Re: Packet loss for the past four days
3.0 Downstream channels
44350000002.20000140.946209QAM2564
14110000003.00000040.366287QAM2561
24190000002.50000038.983261QAM2562
34270000002.09999838.983261QAM2563
54430000002.40000240.366287QAM2565
64510000002.50000040.366287QAM2566
74590000002.59999840.946209QAM2567
84670000002.70000140.946209QAM2568
94750000002.59999840.366287QAM2569
104830000002.59999840.946209QAM25610
114910000002.40000238.983261QAM25611
124990000002.40000238.983261QAM25612
135070000002.50000040.366287QAM25613
145150000002.50000040.366287QAM25614
155230000002.50000040.366287QAM25615
165310000002.90000240.366287QAM25616
175390000002.90000240.946209QAM25617
185470000002.79999940.366287QAM25618
195550000002.90000240.366287QAM25619
205630000002.70000140.366287QAM25620
215710000002.70000140.366287QAM25621
225790000002.70000140.946209QAM25622
235870000002.59999840.946209QAM25623
245950000002.20000140.946209QAM25624
256030000002.00000040.366287QAM25625
266110000001.70000140.366287QAM25626
276190000001.50000040.366287QAM25627
286270000001.29999938.605377QAM25628
296350000001.00000038.983261QAM25629
306430000001.09999838.983261QAM25630
316510000001.09999838.983261QAM25631
4Locked000
1Locked2124843900
2Locked2104200900
3Locked1798457300
5Locked2114818100
6Locked2109142600
7Locked1818495100
8Locked2205035000
9Locked2352300300
10Locked2362020500
11Locked2054592300
12Locked2043660620
13Locked2350986000
14Locked2354143100
15Locked2045271010
16Locked871813100
17Locked1006532410
18Locked986900000
19Locked870965700
20Locked871470910
21Locked993890800
22Locked960927010
23Locked879748710
24Locked1341685120
25Locked1494748600
26Locked1492967010
27Locked1365665600
28Locked1354675710
29Locked1450327910
30Locked1481374410
31Locked339534895020
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096728
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 0.916245856540
inf
  • 20
3.0 Upstream channels
14620000039.0205995120 KSym/sec64QAM11
22580000038.2705995120 KSym/sec64QAM14
33260000038.7705995120 KSym/sec64QAM13
43940000039.0205995120 KSym/sec64QAM12
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Please post a 'Live Link' to your BQM on here.
inf
  • 20
inf
  • 20
I rebooted just after 10am... The packet loss has gone temporarily. Does this imply that the problem is with the HUB4 hardware?
