slappy
  • 34
Message 1 of 23
Packet loss PR7
Had lots of issues over Xmas. They seemed to get fixed around 28th
The past week getting lots of packet loss, you can see the spikes.
It is causing disconnects from VPN and in games
pfSense reports it starting on 17/1/2023 and slowly getting worse.
Not sure if its SNR issue or local issue
3.0 Downstream channels
21470000004.90000234.925610QAM2562
11390000005.30000334.925610QAM2561
31550000004.69999735.083549QAM2563
41630000004.50000035.083549QAM2564
51710000004.30000335.083549QAM2565
61790000003.90000234.925610QAM2566
71870000003.59999835.083549QAM2567
81950000003.40000234.925610QAM2568
92030000003.20000134.925610QAM2569
102110000003.09999834.925610QAM25610
112190000003.20000135.083549QAM25611
122270000003.00000035.083549QAM25612
132350000002.59999835.083549QAM25613
142430000002.09999835.083549QAM25614
152510000002.09999834.483570QAM25615
162590000002.00000035.083549QAM25616
172670000002.20000134.925610QAM25617
182750000002.40000235.083549QAM25618
192830000002.20000135.083549QAM25619
202910000002.29999935.083549QAM25620
212990000002.09999835.595078QAM25621
223070000002.20000135.779911QAM25622
233150000002.29999935.595078QAM25623
243230000002.20000135.779911QAM25624
253310000001.90000235.779911QAM25625
263390000001.20000134.925610QAM25626
273470000000.20000135.083549QAM25627
28355000000-0.20000134.483570QAM25628
29363000000-0.29999934.925610QAM25629
303710000000.00000034.925610QAM25630
313790000000.50000035.083549QAM25631
2Locked34.9256101530
1Locked34.9256101700
3Locked35.0835491520
4Locked35.083549700
5Locked35.083549600
6Locked34.925610800
7Locked35.0835491670
8Locked34.9256101470
9Locked34.9256101960
10Locked34.925610640
11Locked35.083549400
12Locked35.083549450
13Locked35.083549630
14Locked35.083549890
15Locked34.4835708370
16Locked35.083549450
17Locked34.925610400
18Locked35.083549400
19Locked35.083549640
20Locked35.083549380
21Locked35.595078220
22Locked35.77991170
23Locked35.59507850
24Locked35.779911140
25Locked35.779911170
26Locked34.925610820
27Locked35.0835492770
28Locked34.4835705280
29Locked34.9256102900
30Locked34.9256102910
31Locked35.0835491570
3.1 Downstream channels
159964K1880QAM4096759
159Locked35-8.657791426710947445
Tags (2)
slappy
  • 34
Message 2 of 23
Re: Packet loss PR7
Just happened again VPN down, very annoying
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 3 of 23
Re: Packet loss PR7
Looks like your DOCSIS 3.1 channel doesn't have enough power to give a stable connection.
Way too many 'Uncorrectables'.
slappy
  • 34
Message 4 of 23
Re: Packet loss PR7
I did notice the power difference on channels 27 onwards correlated with the increase in errors
So what's the fix?
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 5 of 23
Re: Packet loss PR7
So what's the fix?
Report to VM and they'll check if it's a local area issue, or specific to your line.
ColinsDad
  • 7
Message 6 of 23
Re: Packet loss PR7
Virgin are throttling your connection in peak hours, you are not guaranteed a specific speed, jus a minimum] if you pay for gigabit.
Using third party software to monitor your connection isn't reliable, but I very much doubt Virgin reducing the downstream is your issue, it is most likely the way you are using the equipment in your home causing the issue, because you need no more than 1Mb to run online gaming.
World of Warcraft is one of the most bandwidth hungry games ou there and it uses tiny amounts of data.
I imagine any difficulty you are experiencing is packet loss through a low quality hub or bad GPU driver
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 7 of 23
Re: Packet loss PR7
VM don't throttle.
  • 13.9K
  • 1.08K
  • 2.82K
Message 8 of 23
Re: Packet loss PR7
"Virgin are throttling your connection in peak hours" rubbish, VM do not throttle connections. It look to me to be problem with the high frequencies and unless there is an area fault reported it’s probably a cabinet fault, possibly a bad amp.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
slappy
  • 34
Message 9 of 23
Re: Packet loss PR7
If you look at the traffic graph you will see its pfSense, this is running on enterprise hardware. GPU drivers may drop frames but not create latency on networks. I agree most games do not use a lot of bandwidth.
My issue is the packet loss is significant at times causing the VPN to drop when I work or games to disconnect when IO am playing so with respect if you do not know what you are talking about, don't talk as it just causes frustration
Thankyou to others
I thought the point of this place was so I do not have to ring up and a ticket would be raised and the issue investigated by VM
gitty
  • 257
  • 67
Superfast
Message 10 of 23
Re: Packet loss PR7
Can you post the upstream channels and the network log?
