Danbeasant
  • 5
Packet Loss
Since moving over to Gig1, I am experiencing constant packet loss on my connection. If I simply run a ping to google when on Ethernet, I experience every 10-15 pings timeout.
Its really frustrating, as the kids use the connection for cloud gaming and it causes lag and makes it unusable.
Is there anything I can do to fix this. I am up for calling the vm, but they seem to think the connection is fine, even after I explain to them that packet loss on the network is an issue.
Daniel
Anankha
  • 2.41K
  • 171
  • 523
Problem sorter
Re: Packet Loss
I would try going into the Router’s settings & turning off the firewall then testing the packet loss again after a few minutes.
My Broadband Ping - Virginmedia
  • 20.47K
  • 828
  • 2.2K
Re: Packet Loss
do you get pings timeout if you run
ping -n 200 194.168.4.100
can you test on another wired device?
John_GS
  • 15.66K
  • 798
  • 1.46K
Re: Packet Loss
Hi Danbeasant
Thanks for posting and apologies for the packet loss issue you're experiencing. As a gamer myself I fully appreciate the frustration. Done a system check today and you do have low SNR (signal to noise ratio) on a few of your downstream channels. They also are approaching being maxed out on their levels so could do with lowering these. I shall send you a PM now to book in a technician visit.
Best,
John_GS
