IsaacKingsley
  • 79
  • 5
Dialled in
Message 1 of 55
Packet Loss and latency spikes again
November last year going in up till march-ish I had high latency spikes due to congestion. That eventually got resolved.
2 weeks ago I got a text message from VM mentioning essential network work was happening (and then another about it finishing).
Since then I've had ping spikes but not as bas as last time, but now also packet loss.
Area Reference: 20
Tags (2)
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 2 of 55
Re: Packet Loss and latency spikes again
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. The forum software will remove the MAC addresses for you (If you get an error - just click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
IsaacKingsley
  • 79
  • 5
Dialled in
Message 3 of 55
514750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
15147500002.740256 qam48
2330750000240256 qam25
33387500002.438256 qam26
43467500002.240256 qam27
53547500001.540256 qam28
63627500001.740256 qam29
7370750000240256 qam30
83787500002.240256 qam31
9386750000240256 qam32
103947500002.240256 qam33
11402750000240256 qam34
12410750000238256 qam35
134187500002.240256 qam36
144267500002.540256 qam37
154347500002.738256 qam38
164427500002.740256 qam39
174507500002.740256 qam40
184587500002.740256 qam41
194667500002.240256 qam42
204747500002.240256 qam43
214827500002.240256 qam44
224907500002.440256 qam45
234987500001.738256 qam46
245067500002.440256 qam47
1Locked40.920
2Locked40.300
3Locked38.950
4Locked40.360
5Locked40.300
6Locked40.940
7Locked40.350
8Locked40.940
9Locked40.300
10Locked40.350
11Locked40.350
12Locked38.900
13Locked40.940
14Locked40.960
15Locked38.900
16Locked40.350
17Locked40.340
18Locked40.340
19Locked40.350
20Locked40.350
21Locked40.350
22Locked40.350
23Locked38.910
24Locked40.360
13940000039512032 qam4
23260000039512032 qam5
34620000039512016 qam3
45369999839512064 qam2
3ATDMA0000
4ATDMA0000
IsaacKingsley
  • 79
  • 5
Dialled in
Message 4 of 55
BBQM 2021-12-06BBQM 2021-12-06
Ashleigh_C
  • 4.26K
  • 170
  • 319
Message 5 of 55
Hi there @IssacKingsley
Thank you so much for your post and I am so sorry to see that you have noticed these issues.
I have checked your Hub and can see that everything is working in spec.
Can I ask how things are looking since your last post?
Thank you.
Ash_C
IsaacKingsley
  • 79
  • 5
Dialled in
Message 6 of 55
Still some ping spikes and spots of packet loss throughout the day. It dropped completely during the night for 15 minutes or so
IsaacKingsley
  • 79
  • 5
Dialled in
Message 7 of 55
It got worse again. This is the exact same thing as last year, usable during the day and latency for days during the evening. Playing online games is near impossible
Andrew-G
  • 10.43K
  • 1.66K
  • 4.77K
Message 8 of 55
You have an upstream noise problem, evident in the data you posted earlier.  On a good connection, the upstream has 4 channels working at 64 QAM (in simple terms think of QAM as a data rate).  Your was showing two channels dropping to 32 QAM, and one to 16 QAM.  When the upstream goes to pot, it affects latency and reliability,  but often doesn't show up as an upload speed problem.  It is possible that when Ashleigh_C looked earlier the upstream was performing well because these faults are often intermittent, but they could perhaps have spotted the evidence in the data you posted.
If the problem continues and there's no area fault then you need a technician visit to fix it.
Steven_L
  • 10.28K
  • 624
  • 1.07K
Message 9 of 55
Thanks for giving us some more information about the issues @IsaacKingsley.
There is a noise issue as @Andrew-G suggested in the last post, we will need to send out an engineer to resolve this.
I can book the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Please look out for the private message and we can get started.
Regards,
Steven_L
Steven_L
  • 10.28K
  • 624
  • 1.07K
Message 10 of 55
Thanks for confirming your details @IsaacKingsley.
I have arranged for the appointment and you can find all the information that you need about this on your online account by clicking My Account and Track Your Order.
Regards,
Steven_L
