Tysmy
Packet Loss 60%
Please can someone explain the below to me.
It's when I ping my XBOX
PING 192.168.0.10 (192.168.0.10): 64 data bytes
72 bytes from 192.168.0.10: seq=0 ttl=128 time=0.000 ms
72 bytes from 192.168.0.10: seq=0 ttl=128 time=120.000 ms (DUP!)
72 bytes from 192.168.0.10: seq=1 ttl=128 time=1400.000 ms
72 bytes from 192.168.0.10: seq=1 ttl=128 time=3160.000 ms (DUP!)
72 bytes from 192.168.0.10: seq=2 ttl=128 time=8690.000 ms
72 bytes from 192.168.0.10: seq=2 ttl=128 time=10380.000 ms (DUP!)
72 bytes from 192.168.0.10: seq=3 ttl=128 time=13290.000 ms
--- 192.168.0.10 ping statistics ---
10 packets transmitted, 4 packets received, 3 duplicates, 60% packet loss
  • 16.27K
  • 710
  • 1.6K
Re: Packet Loss 60%
Get your own router with 1Gb ports and use the hub in modem mode.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Packet Loss 60%
What is your contracted speed ?
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
