mustafa649
  • 19
Message 1 of 14
Packet Loss 24/7
I have been getting packet loss for a couple of weeks and i recently started monitoring my internet
04/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1d669ecce312f9241efb4d929254f18f7c819f57-04-07-2020
 05/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f082a673adf2ed6c7d7fab26024aa1bd92ba2c66-05-07-2020
06/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/6ad84aa46e60a76fc95492e442a345cb40...
 07/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/575fe69d440e8967029aa24a51b82c7d37f7b1a7-07-07-2020
 08/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b2ed664e1d3157d3390eea1a1879d7bcae294439-08-07-2020
09/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/dea9b8945e627cd5672c0ce7ff30dc0affd607f6-09-07-2020
10/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/61ae891a336b580f563a99429f6862d7d71af5a9-10-07-2020
11/07/20
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0940310cca46d658e29e13ac3b25259b6c408c54-11-07-2020
Tags (1)
jpeg1
  • 4.52K
  • 254
  • 729
Community elder
Message 2 of 14
Re: Packet Loss 24/7
You are right. That packet loss is not normal. Can you post your downstream, upstream and network log please.
mustafa649
  • 19
Message 3 of 14
435000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
mustafa649
  • 19
Message 4 of 14
1435000000540256 qam36
2235000000640256 qam13
32430000005.540256 qam14
42510000005.340256 qam15
52590000005.540256 qam16
6267000000640256 qam17
7275000000640256 qam18
8283000000640256 qam19
92910000005.940256 qam20
10299000000640256 qam21
113070000006.340256 qam22
123150000006.440256 qam23
133230000006.140256 qam24
143470000006.140256 qam25
153550000006.340256 qam26
163630000006.340256 qam27
17371000000640256 qam28
183790000005.540256 qam29
193870000005.440256 qam30
203950000005.440256 qam31
214030000005.540256 qam32
224110000005.140256 qam33
234190000004.940256 qam34
244270000004.940256 qam35
1Locked40.990
2Locked40.340
3Locked40.370
4Locked40.300
5Locked40.370
6Locked40.3100
7Locked40.970
8Locked40.360
9Locked40.350
10Locked40.390
11Locked40.990
12Locked40.390
13Locked40.300
14Locked40.350
15Locked40.950
16Locked40.990
17Locked40.350
18Locked40.380
19Locked40.350
20Locked40.3200
21Locked40.9170
22Locked40.380
23Locked40.380
24Locked40.360
mustafa649
  • 19
Message 5 of 14
1326000003.875512032 qam5
2394000003.975512064 qam4
3462000004.075512032 qam3
4537000004.175512064 qam2
3ATDMA0000
4ATDMA0000
mustafa649
  • 19
Message 6 of 14
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69834n
SFID14931
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID14930
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
mustafa649
  • 19
Message 7 of 14
09/07/2020 10:01:37 critical No Ranging Response received - T3 time-out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:53 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:53 Warning! RCS Partial Service;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:52 Warning! RCS Partial Service;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:48 Warning! RCS Partial Service;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:42:48 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:40:40 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 09:40:40 Warning! RCS Partial Service;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:49:13 critical No Ranging Response received - T3 time-out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:47:55 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:45:33 critical No Ranging Response received - T3 time-out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:21:21 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 14:50:13 critical No Ranging Response received - T3 time-out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 14:49:27 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 14:05:16 critical No Ranging Response received - T3 time-out;CM-MAC=***********************;CMTS-MAC=***********************;CM-QOS=1.1;CM-VER=3.0;
jpeg1
  • 4.52K
  • 254
  • 729
Community elder
Message 8 of 14
The log shows where the feed dropped out completely, but apart from that there is no explanation for the constant packet loss. The signal levels both ways are fine, as is the snr.
It would be interesting to get other opinions on this but I think you will need an engineer visit to check this out at the cabinet.
Anonymous
Not applicable
Message 9 of 14
Two of the four upstream channels aren't on the correct modulation, which is a bit of a concern.
jpeg1
  • 4.52K
  • 254
  • 729
Community elder
Message 10 of 14
Yes, but that shouldn't cause such a packet loss.
Your own BQM still looks awful. No help yet?
