PS4 download speed over WiFi
When connecting my PS4 to the hub 3 over WiFi I only get a download speed of around 500 Kbps to 1.5 mbps.
i don’t use the PS4 for online gaming but use it to stream Netflix and amazon prime, my only source of TV.
No LAN cable available.
virgin media only installed 2 days ago.
any help would be appreciated.
thanks
  • 15.68K
  • 1.64K
  • 2.68K
Re: PS4 download speed over WiFi
As its your only source you should really try to get it connected on Cat6 ethernet cable. Long runs of up to 50m are cheap from the usual online places and if you get the flat stuff it isnt too difficult to conceal around skirting boards, under carpets etc. Or external grade can be run outside.
