Warbo666
  • 11
Message 1 of 9
Outages, Latency Issues, Packets dropped - Help?
Hi All,
So I'm back with yet again poor speeds, but also finding extremely high latency issues (I've been trying to play some Rocket League on PS4 through a ethernet/wired connection, but the lag makes it entirely unplayable) , but also having several drop-outs of a minute or so which causes devices to disconnect, and so forth.
Hub Data:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
571000000
3.4
37
256 qam
21
2
411000000
4.1
37
256 qam
1
3
419000000
4.3
37
256 qam
2
4
427000000
4.1
37
256 qam
3
5
435000000
4
37
256 qam
4
6
443000000
3.9
37
256 qam
5
7
451000000
3.7
37
256 qam
6
8
459000000
4.3
37
256 qam
7
9
467000000
4.4
37
256 qam
8
10
475000000
4.5
38
256 qam
9
11
483000000
4
37
256 qam
10
12
491000000
3.9
37
256 qam
11
13
499000000
3.5
37
256 qam
12
14
507000000
3.7
37
256 qam
13
15
515000000
3.7
37
256 qam
14
16
523000000
3.9
37
256 qam
15
17
531000000
3.4
37
256 qam
16
18
539000000
3.7
37
256 qam
17
19
547000000
3.9
37
256 qam
18
20
555000000
3.5
37
256 qam
19
21
563000000
3.7
37
256 qam
20
22
579000000
3.5
37
256 qam
22
23
587000000
3.4
37
256 qam
23
24
595000000
3.7
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
538
0
2
Locked
37.6
2591
0
3
Locked
37.6
2177
0
4
Locked
37.3
1948
0
5
Locked
37.6
1671
0
6
Locked
37.6
1758
0
7
Locked
37.6
1826
0
8
Locked
37.3
1461
0
9
Locked
37.6
1713
0
10
Locked
38.6
1680
0
11
Locked
37.3
2156
0
12
Locked
37.6
2327
0
13
Locked
37.3
2100
0
14
Locked
37.3
1979
0
15
Locked
37.6
1737
0
16
Locked
37.6
1324
0
17
Locked
37.6
1281
0
18
Locked
37.3
1135
0
19
Locked
37.3
959
0
20
Locked
37.6
802
0
21
Locked
37.6
708
0
22
Locked
37.6
338
0
23
Locked
37.6
288
0
24
Locked
38.6
160
0
ime
Priority
Description
13/01/2021 22:16:43
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 05:58:34
critical
12/01/2021 22:13:41
notice
SW download Successful - Via Config file
12/01/2021 22:11:11
notice
SW Download INIT - Via Config file
12/01/2021 21:40:5
notice
12/01/2021 02:08:42
critical
01/01/1970 00:06:16
critical
DHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:05:8
critical
01/01/1970 00:04:26
critical
DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:50
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:44
critical
12/01/2021 02:00:49
notice
SW download Successful - Via NMS
12/01/2021 01:58:47
notice
SW Download INIT - Via NMS
10/01/2021 16:13:30
notice
10/01/2021 16:12:55
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 17:11:54
critical
08/01/2021 16:09:22
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 16:09:22
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 17:53:19
critical
05/01/2021 04:09:22
notice
BQM
BQM ACTIVITY
As you can see there is a significant amount of latency, but also, there is a 10-20% of dropped packets on a regular basis.
Can anyone from Virgin please advise? Is my Hub (3.0) to blame for this? or is this a wider issue? It's a real pain as I need video conferencing for work, but can't ever achieve a stable enough connection for video (I can just about make it with audio-calls on Teams) but even then I sometimes experience the drop-outs.
Thanks.
Warbo666
  • 11
Message 2 of 9
Re: Outages, Latency Issues, Packets dropped - Help?
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300024
40
5120
64 qam
1
2
39399961
40
5120
64 qam
4
3
46199983
40
5120
64 qam
3
4
53700000
40
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
v9873254k;fg87dsfd;kfoA,.iyew
SFID
3123
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
3182
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Anonymous
Not applicable
Message 3 of 9
Certainly looks like local oversubscription/utilization with it settling in the early hours:
Warbo666
  • 11
Message 4 of 9
Hi Carl, does that mean it's simply a case of having to just having to deal with it for the foreseeable future?
My download speeds are also erratic - earlier today I was managing just 2-5mbps, whereas I've just ran one now and am getting 26mbps. However, yesterday around 7pm I was getting 95mbps. I'd much rather a middle of the range speed if it mean that my connection was consistent.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 9
Looking at your BQM they only time you will get a consistent connection is from 02:00 to 08:0 due to the utilisation issues which to be honest are to be expected.
A good friend of the forums @Andruser has commented on the forum about similar problems to yours ...
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
Warbo666
  • 11
Message 6 of 9
Thanks MikeRobbo for your input... feel a little bit helpless about what to do now. 😔
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
You could always change your working regime to 23:59 to 08:00 then you will have all day to get the housework done 😁
Anonymous
Not applicable
Message 8 of 9
Shhh.... it will catch on and we'll be back to square one!
Warbo666
  • 11
Message 9 of 9
So apparently I've had 100% dropped packets from 6pm on Friday 21st January all the way through Saturday 22nd January (I'm writing this at 23:40)...  does this mean anything? I'm still on the internet, and function seems okay (still getting minor drop-outs/or notification of poor signal on video calls) so wondering if there is something potentially wrong with the router?
