elmarcos14
  • 11
Message 1 of 17
Ooomph 500 Speed Dropped After Network Outage
Suffered a network outage in my local area on 26/08/2020 and since then when it came back on my speeds have never been the same. Stats are as follows:
12670000003.240256 qam17
2139000000840256 qam1
31470000008.440256 qam2
41550000008.540256 qam3
51630000008.440256 qam4
61710000008.440256 qam5
71790000008.340256 qam6
8187000000840256 qam7
91950000007.640256 qam8
102030000007.540256 qam9
112110000007.340256 qam10
122190000007.140256 qam11
132270000006.540256 qam12
142350000006.340256 qam13
152430000005.640256 qam14
162510000005.340256 qam15
17259000000440256 qam16
182750000004.538256 qam18
192830000005.638256 qam19
202910000006.140256 qam20
212990000006.640256 qam21
22307000000740256 qam22
233150000007.140256 qam23
24323000000738256 qam24
1Locked40.300
2Locked40.900
3Locked40.340
4Locked40.9170
5Locked40.350
6Locked40.360
7Locked40.960
8Locked40.350
9Locked40.3150
10Locked40.350
11Locked40.930
12Locked40.940
13Locked40.360
14Locked40.370
15Locked40.350
16Locked40.350
17Locked40.350
18Locked38.650
19Locked38.950
20Locked40.360
21Locked40.300
22Locked40.360
23Locked40.950
24Locked38.600
elmarcos14
  • 11
Message 2 of 17
Re: Ooomph 500 Speed Dropped After Network Outage
1536999764.75512064 qam2
2393999964.5512064 qam4
3462000024.6512064 qam3
4602999864.75512064 qam1
3ATDMA0000
4ATDMA0000
elmarcos14
  • 11
Message 3 of 17
07/09/2020 19:32:32noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/09/2020 16:11:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 21:18:29noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 16:17:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 16:51:2noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 16:51:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 21:21:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 06:05:45noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 06:05:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 13:01:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 10:52:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 10:52:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 10:52:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 10:51:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:58:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:39:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:39:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 06:44:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 06:44:54Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 02:58:9criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
elmarcos14
  • 11
Message 4 of 17
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3fcc8d9fd49979362452120115dc9fed50a5a46c
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 17
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
elmarcos14
  • 11
Message 6 of 17
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 17
Your >> BQM << has just started but I can see that it is displaying quite high latency.
You may be affected by local high utilisation.
I would advise you to wait for one of the VM Staff to pick up the thread but this may take a few days.
John_GS
  • 8.7K
  • 476
  • 769
Message 8 of 17
Hi elmarcos14
Thanks for posting and welcome to the community. My apologies for the lower than expected speeds.
I've had a check on our system today and the levels are all in spec, no issues showing.
The speedtests you've ran, were they done on a wireless or a wired connection?
Kind regards,
John_GS
elmarcos14
  • 11
Message 9 of 17
They were on a wired connection and in modem mode.
John_GS
  • 8.7K
  • 476
  • 769
Message 10 of 17
Thanks can you do the test in router mode (wired) with only 1 device connected to the internet?
Kind regards
John_GS
