merlinblue
  • 20
Message 1 of 7
Only getting half of my speed
Hi, please can somebody check my levels. I pay for 200Mbps but am only getting 90Mbps. The results below are with an Ethernet connection with one device connected.
1 323000000 4.5 40 256 qam 24
2 139000000 3.2 38 256 qam 1
3 147000000 2.9 37 256 qam 2
4 155000000 2.7 38 256 qam 3
5 163000000 2.7 38 256 qam 4
6 171000000 2.7 38 256 qam 5
7 179000000 2.7 38 256 qam 6
8 187000000 2.7 38 256 qam 7
9 195000000 2.7 38 256 qam 8
10 203000000 2.7 38 256 qam 9
11 211000000 2.7 38 256 qam 10
12 219000000 2.7 38 256 qam 11
13 227000000 2.5 38 256 qam 12
14 235000000 2.5 38 256 qam 13
15 243000000 2.2 38 256 qam 14
16 251000000 2.2 38 256 qam 15
17 259000000 1.9 38 256 qam 16
18 267000000 2.7 38 256 qam 17
19 275000000 3 38 256 qam 18
20 283000000 3.5 38 256 qam 19
21 291000000 3.7 38 256 qam 20
22 299000000 4 38 256 qam 21
23 307000000 4 38 256 qam 22
24 315000000 4 38 256 qam 23
1 Locked 40.3 1 0
2 Locked 38.6 23 0
3 Locked 37.6 17 0
4 Locked 38.6 5 0
5 Locked 38.6 6 0
6 Locked 38.6 6 0
7 Locked 38.6 7 0
8 Locked 38.6 6 0
9 Locked 38.6 6 0
10 Locked 38.6 7 0
11 Locked 38.6 5 0
12 Locked 38.9 8 0
13 Locked 38.9 6 0
14 Locked 38.9 8 0
15 Locked 38.6 1 0
16 Locked 38.9 6 0
17 Locked 38.6 3 0
18 Locked 38.9 6 0
19 Locked 38.6 6 0
20 Locked 38.9 4 0
21 Locked 38.9 10 0
22 Locked 38.6 7 0
23 Locked 38.9 4 0
24 Locked 38.9 7 0
1 60300068 4.325 5120 64 qam 1
2 39399996 4.075 5120 64 qam 4
3 46199966 4.175 5120 64 qam 3
4 53699974 4.325 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
05/07/2020 12:56:12 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 01:34:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 19:59:38 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:46:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:27:15 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:26:33 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:26:28 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:26:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:26:27 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:22:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:16:37 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:15:54 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:15:50 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:15:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 00:15:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:54:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:48:53 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:48:8 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:48:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:48:3 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks in advance.
  • 22.35K
  • 2.4K
  • 3.99K
Message 2 of 7
Re: Only getting half of my speed
Are you limited to 100mbps by using a Cat5 cable (or a faulty one?) or by having a 10/100 NIC card in your device? Are the drivers up to date? Check in your settings what the speed is set to - should read 1GB - not 100mbps.
merlinblue
  • 20
Message 3 of 7
Thanks for the reply. Brand new CAT6 cable connected directly to SH3. Network card drivers up to date. NIC card showing 1.0 gb. No other devices connected to the network at time of testing.
  • 22.35K
  • 2.4K
  • 3.99K
Message 4 of 7
OK - Couple of things.
Can you do the speedtest once more as before but with the device booted into safe+networking mode - just to rule out anything on there restricting speeds (lots of software does!).
Also have you ever had >100mbps? And did you recently upgrade to the 200 from 50/100? Just wondering whether the Hub has been correctly provisioned for the 200 service. Can you check by looking in the Hub settings at the "config file" and see what number is in the downstream "max data transfer rate box. should be ~230000000.
-tony-
  • 16.52K
  • 1.31K
  • 3.9K
Message 5 of 7
assuming nothing in the post above is relevant do a speed test with the hub in modem mode
____________________
Tony
merlinblue
  • 20
Message 6 of 7
Thank you for the useful advice again. I'll try these steps later as the kids are using the internet at the moment and I daren't kick them off. More than my life is worth. I'll post the results later/tomorrow. Thank you.
merlinblue
  • 20
Message 7 of 7
Getting over 200 today. Not sure what changed. I'll keep an eye on it for a few days but all seems well at the moment. Thanks for the help.
