Gregerz85
  • 5
Message 1 of 8
Ongoing broadband issues
Sorry if this is on the wrong board but I’ve been having issues with my fluctuating broadband speeds for quite a while now. I checked the network log on the router status page and noticed a lot of critical errors that keep occurring pretty much daily.
from what I’ve read it could be due to the power levels being abnormally high (or low as the case may be).
can anyone please confirm this and help me with a potential fix please
17/09/2020 01:24:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:04:50criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:04:43criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:02:50criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:01:2criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 01:00:54criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:59:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:58:5criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:56:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:56:10criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:54:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:36:39criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:34:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:28:31criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:27:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:27:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 00:27:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Ongoing broadband issues
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Hub 3 When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Gregerz85
  • 5
Message 3 of 8
https://www.thinkbroadband.com/broadband/monitoring/quality/share/eb2914f4edf8e630676a2d47b136d8f2f4...
13870000003.740256 qam32
22030000005.538256 qam9
3211000000538256 qam10
4219000000540256 qam11
52270000004.638256 qam12
62350000004.538256 qam13
72430000004.438256 qam14
82510000004.538256 qam15
92590000004.440256 qam16
10267000000438256 qam17
112750000003.738256 qam18
122830000003.540256 qam19
132910000003.538256 qam20
142990000004.838256 qam21
153070000004.938256 qam22
16315000000538256 qam23
17323000000538256 qam24
183310000004.838256 qam25
193390000004.838256 qam26
203470000004.640256 qam27
213550000004.540256 qam28
223630000004.140256 qam29
23371000000440256 qam30
24379000000438256 qam31
1Locked40.3160
2Locked38.6130
3Locked38.9110
4Locked40.3120
5Locked38.6160
6Locked38.9110
7Locked38.9140
8Locked38.6120
9Locked40.3120
10Locked38.9140
11Locked38.9200
12Locked40.3170
13Locked38.9140
14Locked38.9120
15Locked38.9370
16Locked38.9100
17Locked38.9230
18Locked38.9290
19Locked38.9280
20Locked40.3200
21Locked40.3220
22Locked40.3120
23Locked40.3120
24Locked38.9190
1461999964.3512064 qam1
2258000124.15512064 qam4
3326000044.3512064 qam3
4394000194.3512064 qam2
3ATDMA0000
4ATDMA0000
Gregerz85
  • 5
Message 4 of 8
TimePriorityDescription17/09/2020 01:24:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:04:50criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:04:43criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:02:50criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:01:2criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 01:00:54criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:59:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:58:5criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:56:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:56:10criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:54:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:36:39criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:34:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:28:31criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:27:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:27:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:27:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:27:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/09/2020 00:27:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 16.25K
  • 710
  • 1.6K
Message 5 of 8
Looks good so far...
Maybe your issues is with wifi?
Gregerz85
  • 5
Message 6 of 8
Sorry the network log didn’t format very well, I’ve included it again
Gregerz85
  • 5
Message 7 of 8
I keep getting dropouts all the time and even with a wired connection I get 44mbps and occasionally jumps to 100mbps. Bit of a bummer when you pay for up to 200mbps if that makes sense.
surely all those critical and warning messages in the log mean something isn’t right??
Emma_C
  • 8.28K
  • 512
  • 559
Message 8 of 8
Hi Gregerz85,
I'm really sorry you've been having some on going broadband issues, this isn't what we like to hear.
I'd also like to apologise for the delay in getting back to you, we have been busier than normal.
I've had a look into the back end of the services and we've identified a short term network issue that could cause degradation or an intermittent service.
We believe it will only be a short term issue and it will be fixed very soon. However, in the mean time, it would be great if you could check that the coax cables are connected securely to your equipment, any splitters (standard and powered) and to the wall socket.
Let us know how you're getting on with things.
Emma_C - Forum Team
