on 03-11-2022 17:38
had 350mb under O2 volt deal was workiing well , then checked a few weeks ago and it was stuck at about 90mb.
just signed up for 18 months and reduced speed to 200mb ..............still getting 90mbs , have reset the hub a number of times, pulled the plug out etc but no change
on 04-11-2022 16:38
on 04-11-2022 22:29
i am directly plugging an ethernet cable from the hub into the PC, it was running at full speed a while back but not anymore
on 04-11-2022 22:33
on 04-11-2022 23:45
Hi @Petezd
Also try a different ethernet cable.
on 05-11-2022 13:30
on 06-11-2022 09:39
changed cable, direct link to hub and the adaptor is set at 1gb still maxing about 80-90mb
on 06-11-2022 10:13
Try a different port on the Hub.
on 06-11-2022 11:51
on 06-11-2022 15:47
