Hello,
2 days ago I upgraded from 100mb (which worked perfectly) to 200mb. Mainly because working from home and doing lots of video conferencing it seemed the best idea.
I was told that speeds will fluctuate for a few hours then steady at 200Mb up and 20Mb down.
I run a wifi mesh system due to the Hub not covering all areas of my house so the Hub3 is in modem mode. I'm currently getting about 100-135Mb down and 20Mb up via 5Ghz wifi and 130-150Mb and 20Mb up via cat6 cable. Not sure why. I have checked my cables and everything is 1gig cables so shouldn't be a problem there and my internet was always max 100Mb on my previous contract with you.
I should say that about a year ago when virgin came to fit everything at my house for the first time (It had no previous connection) They had to fit a little silver db amplifier type thing so I could get the correct speeds they said. Not sure if this is now not enough to reach the newer speed.
Any help will be greatly appreciated.
Alex
