PENNELS
  • 8
Message 1 of 16
Not receiving Upgraded Speed
I upgraded from the M100 to the M350 Broadband package 2 days ago. Since then, my speed hasn't increased and remains around 45Mbps. I have checked the Hub 3.0 settings to ensure that it is configured to allow a 350Mbps speed and it is. Any help please.
Tags (2)
jpeg1
  • 4.23K
  • 236
  • 675
Community elder
Message 2 of 16
Re: Not receiving Upgraded Speed
What device are you using to measure them speed, and how is it connected to the hub?
Post the configuration data here.
PENNELS
  • 8
Message 3 of 16
Would you like all the Config data?
It is connected via Ethernet, and i'm using Speedtest.net and another called Fast.com. Both show the same result.
  • 20.62K
  • 2.19K
  • 3.64K
Message 4 of 16
Just the info in the up/down Maximum Data Transfer Rate boxes - these are in bps
sayekm
  • 316
  • 27
  • 59
Fibre optic
Message 5 of 16
I am guessing you also go 45mbs on M100 prior the upgrade.
You should have got 110mbs on M100 off peak and if not should have got this sorted before upgrade. Getting an upgrade on a faulty connection not gonna boost the speed much.
It may help if you post your router stats here and maybe someone can see if anything obvious.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
PENNELS
  • 8
Message 6 of 16
Here it is:
SFID 524838
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 524837
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
PENNELS
  • 8
Message 7 of 16
I'm currently on my computer upstairs which is connected Via Ethernet into a set of Devolo internet boost boxes so this PC has always experienced slower than what my laptop receives downstairs, but it hasn't changed since i upgraded it.
jpeg1
  • 4.23K
  • 236
  • 675
Community elder
Message 8 of 16
You are on the 350Mb service.
To measure the speed correctly you will need to connect your laptop directly to the Hub, with no other devices connected.
PENNELS
  • 8
Message 9 of 16
Currently unavailable to do it with a Laptop but will as soon as possible. Nevertheless i disconnected all devices but my PC upstairs from the router, and ran a speedtest on my phone connected via Wifi and it gave me 77Mbps. Understandably, due to it being wifi, it isn't the 362Mbps average for this package, but it should still be far greater than 77.
jpeg1
  • 4.23K
  • 236
  • 675
Community elder
Message 10 of 16
Depends which WiFi band your phone is using.  Is it connected on 2 Ghz or 5 Ghz?
