Kuzugara
  • 19
Message 1 of 28
Not hitting the minimum guaranteed speed on m350.
Evening All,
I am a new customer who is paying for m350. Following the onsite suggested help the download speed I get is 83mbps.
I am using 2x Cat7 cables through a powerlink adaptor.
I have resetted my router and have had no luck.
Link to speedtest image - https://imgur.com/a/9bn1q4A
Any suggestions would be great!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 28
Re: Not hitting the minimum guaranteed speed on m350.
Couple of questions ...
Does the device you are testing with have a capable 1Gbs Network Interface Card (NIC) ?
Can you test without the powerlink (powerline?) adaptors in the system?
Kuzugara
  • 19
Message 3 of 28
I must admit my knowledge of Network stuff is pretty terrible.
I wouldn't know if my NIC is capable:
Details of my network properties if it helpful:
Description: Intel(R) Ethernet Connection I217-V
Physical address (MAC): **:**:**:**:**:**
Status: Operational
Maximum transmission unit: 1500
Link speed (Receive/Transmit): 100/100 (Mbps)
DHCP enabled: Yes
DHCP servers: 192.168.0.1
DHCP lease obtained: ‎02 ‎March ‎2020 20:28:43
DHCP lease expires: ‎03 ‎March ‎2020 20:28:43
IPv4 address: 192.168.0.14/24
IPv6 address: fe80::d161:89f9:c5bc:4061%11/64
Default gateway: 192.168.0.1
DNS servers: 194.168.4.100, 194.168.8.100
DNS domain name:
DNS connection suffix:
DNS search suffix list:
Network name: Network 2
Network category: Private
Connectivity (IPv4/IPv6): Connected to Internet / Connected to unknown network
Name: Teredo Tunneling Pseudo-Interface
Description: Microsoft Teredo Tunneling Adapter
Physical address (MAC): **:**:**:**:**:**:00:e0
Status: Operational
Maximum transmission unit: 1280
IPv6 address: 2001:0:2851:7ae4:1c08:801:a9e1:58b/64, fe80::1c08:801:a9e1:58b%10/64
Default gateway: ::
Connectivity (IPv4/IPv6): Disconnected
Unfortunately I don't have another device to test the adaptors.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 28
Status: Operational
DHCP enabled: Yes
DNS domain name:
Status: Operational
Default gateway: ::
8Mbs is indicative of a slow NIC.
Looking at the info you posted yours is 100/100.
Have a look in the NIC settings to see if you can change the speed to 100/1000.
Kuzugara
  • 19
Message 5 of 28
Hi MikeRobbo,
Thanks for helping so far!
So.... how do I go about that? Apologies in advance.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 28
What device and operating system ?
Kuzugara
  • 19
Message 7 of 28
My PC runs on Windows 10.
I've looked around online and it suggests:
1) Network Settings -> Ethernet
2) Change Adapter options
3) Right click and properties
4) Configure and then Advanced.
5) Speed and Duplex and change the value to 1.0 Gbps Full Duplex.
Although when I do this my internet disables itself.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 28
Set it to 1.0Gbps then OK your way out then reboot your PC.
Kuzugara
  • 19
Message 9 of 28
Unfortunately that still left with me no internet and I had to restart it to Auto Negotiation.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 10 of 28
I should have asked this first ...
Have you checked the 'Check Service Status' at the top of the page?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may not be affecting the area. Be aware that it isn't a manned
Type 192.168.0.1 (192.168.100.1 in Modem mode ) into your browser URL bar and press enter.  When the page appears DO NOT LOG IN but click ‘Check Router Status’. Copy and paste the contents of each tab onto here, a Guru will be along soon to decipher the info.
