KBuley
  • 29
Message 1 of 14
Not hitting speed
Having issues with speed. Had M500 for a few weeks now and it’s never gotten up to 500mbs, not even when near the router. Today it is struggling to get to 200. I’ve checked my router status as per your guide and copy and pasted the details;
ItemStatusCommentsAcquired Downstream Channel (Hz)
187000000
Locked
Ranged Upstream Channel (Hz)
25800108
Any help would be appreciated.
Anonymous
Not applicable
Message 2 of 14
Re: Not hitting speed
Is the speed being checked over a wired connection?
  • 5.68K
  • 911
  • 1.34K
Hero
Message 3 of 14
Hi KBuley,
I may be wrong, but to me looking at the figures you posted, you haven't got the M500 configuration.
These pictures show how M500 looks in my settings.router status.jpgstatus.jpg
Dave
KBuley
  • 29
Message 4 of 14
It’s over WiFi.
KBuley
  • 29
Message 5 of 14
Thanks. Is this something I can sort out myself?
Anonymous
Not applicable
Message 6 of 14
It's very unlikely you'll see 500Mbps over wireless.
Having said that if your HUB isn't showing 500Mbps in your configuration tab you won't see the speed regardless!
What does your online account show as the package signed up for?
KBuley
  • 29
Message 7 of 14
It says M500 fibre broadband.
Anonymous
Not applicable
Message 8 of 14
I can't see the image you posted.
Can you copy paste the HUB configuration tab as text (Literally highlight copy, then paste).
KBuley
  • 29
Message 9 of 14
I’m on an iPad, Hope this works.
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Vcb573b2ee9a9587e.cm
SFID239308
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID239307
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Anonymous
Not applicable
Message 10 of 14
You are, in fact, on 500Mbps!
As I said earlier you will probably never see full speed on wireless devices.
I'm on 350Mbps and on an iPad a couple of feet from the HUB I got 300Mbps.
Six - eight feet away I got 220Mbps.
You are seeing hardware, not broadband speed, limitations.
