  • 2.71K
  • 159
  • 341
Trouble shooter
Message 1 of 7
Not having a speed problem but
Not having a speed problem, latest Speedtest - Ping 11 - Download 551.91 - Upload 46.91 I have checked all terminals and they are tight.
Having read this forum on a daily basis I have noted the comments about the upstream and downstream figures at the hub.
My downstream seems to be quite high compared to the expected figures. Should I be expecting problems in the future?
132300000010.537256 qam24
21870000009.538256 qam7
31950000009.938256 qam8
42030000001038256 qam9
52110000001038256 qam10
62190000001038256 qam11
72270000001038256 qam12
82350000001038256 qam13
92430000001038256 qam14
102510000001037256 qam15
112590000001037256 qam16
1226700000010.437256 qam17
1327500000010.137256 qam18
142830000001037256 qam19
152910000001037256 qam20
1629900000010.437256 qam21
1730700000010.537256 qam22
1831500000010.637256 qam23
1937900000010.936256 qam25
2038700000010.836256 qam26
213950000001137256 qam27
2240300000010.636256 qam28
2341100000010.836256 qam29
2441900000010.636256 qam30
1Locked37.34261740
2Locked38.65101320
3Locked38.94426490
4Locked38.93899230
5Locked38.63546620
6Locked38.92906530
7Locked38.62315310
8Locked38.62806380
9Locked38.62429510
10Locked37.63034100
11Locked37.33246470
12Locked37.63347280
13Locked37.63582020
14Locked37.63690820
15Locked37.63963880
16Locked37.64123510
17Locked37.63405020
18Locked37.34180290
19Locked36.68429110
20Locked36.610003650
21Locked37.610712590
22Locked36.615266590
23Locked36.318055640
24Locked36.616598050
Mike Robinson
Ex UK Armed Forces
Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 2.71K
  • 159
  • 341
Trouble shooter
Message 2 of 7
Re: Not having a speed problem but
1394000004.85512064 qam6
2258000004.95512064 qam8
3326000004.85512064 qam7
4462000005512064 qam5
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
d;kfoA,.iyewrkldJKDH
SFID31184
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID31167
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
12/11/2019 18:44:0ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2019 18:44:0noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2019 18:55:12ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2019 14:36:30ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2019 14:36:30noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2019 10:52:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 04:41:37ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 06:57:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 19:42:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:43:4ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:43:4noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 13:30:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2019 15:38:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2019 23:44:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 02:07:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 12:37:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 12:37:23noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 18:03:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2019 19:57:0noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2019 07:06:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mike Robinson
Ex UK Armed Forces
  • 2.16K
  • 333
  • 846
Problem sorter
Message 3 of 7
You are quite right that downstream power levels are too high (and one upstream channel is looking at the maximum allowable).  This ought to be corrected simply because it is outside the spec.  If you're not seeing much impact on speed, that's good, but I'd imagine from the large number of pre-RS errors that it is having some impact on latency (not to mention a few T3 timeouts showing in the log).
I would suggest waiting for the forum staff to pick this up, as it does need sorting out.  If there's an area fault that might fix the issue, if there isn't then you'll need a technician visit.
  • 2.71K
  • 159
  • 341
Trouble shooter
Message 4 of 7
Cheers.
I will wait for VM Staff.
Mike Robinson
Ex UK Armed Forces
  • 1.42K
  • 99
  • 132
Message 5 of 7
Thanks for getting in touch MikeRobbo.
I can take a further look into your account via a private message and look at what is causing the problems on your account.
Steven_L
  • 2.71K
  • 159
  • 341
Trouble shooter
Message 6 of 7
Got message and reponded thanks.
Mike Robinson
Ex UK Armed Forces
  • 2.71K
  • 159
  • 341
Trouble shooter
Message 7 of 7
Engineer has been and all sorted.
Mike Robinson
Ex UK Armed Forces
