Knight499
Not getting what I’m paying for.
I too am not getting what I’m paying for...neither can I get through to anyone on the phone it’s ridiculous!!!
Paying for M200
Speedtest.net result attached.
Many Thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Not getting what I’m paying for.
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Knight499
Wow thanks for detailed reply mike.
I’ll try and give that a go over the weekend and report back.
Not very technically minded but thought I’d try here as finding it impossible to get to speak to anybody over the phone.
Yet when contract is close to running out can’t stop them calling me...funny that !!!
Anonymous
Not applicable
You are using a wireless device which doesn't have full signal so it's bound to be slower than your 200Mbps connection.
As Mike says you need to confirm speeds on a wired device as that's guaranteed, unlike wireless as it's limited by device, signal, etc.
