Not getting the speed im paying for
Since taking out M100 in December I am only getting m50 down load speeds of approx 50mbs, is this normal or is something wrong, I have tried resetting, moving the router around the room and nothing really helps, ideas please....
I've used speedtest.net about 30 to 50 times and never got more than 52mbs down....
  • 11.38K
  • 789
  • 1.61K
Re: Not getting the speed im paying for
What are you using to conduct the test and are you doing it over WiFi or directly into the hub?
I work for Virgin Media and my posts are my own opinions
  • 30.38K
  • 1.52K
  • 5.28K
is that wired or wireless
Actually guys that's 50MB wirelessly, I dont use wired computers... But I totally see where your going with your comments and I do actually need to check that out.
  • 30.38K
  • 1.52K
  • 5.28K
we can advice you on wireless tips but first we need to know if its wireless or a VM problem. Let us know when you test
  • 20.96K
  • 1.14K
  • 2.7K
You need to run a wired test to determine the speeds coming into your hub
