Rikkigt4
Message 1 of 9
Not getting the speed i pay for
I've never checked the speed since signing up a couple of months ago I'm quite disappointed with virgin media i pay for the 350mbps but all the speed tests I've done the maximum I'm getting is141.03mbps if this is the best virgin media can offer I might as well drop to a lower tariff.
is it possible to downgrade.?
Tags (1)
  • 6.8K
  • 591
  • 1.78K
Message 2 of 9
Re: Not getting the speed i pay for
Yes, you can downgrade.
However how are you testing speeds.?  VM do not guarantee wifi speeds, so tests need to be done wired directly to the Hub.
Post your power levels and network logs.  Also setup a BQM here www.thinkbroadband.com/ping
Once done we can comment.
Rikkigt4
Message 3 of 9
I'm wired to the hub with high quality cable testing from virgin media link to speed test.net
Tags (1)
Ashleigh_C
  • 5.31K
  • 194
  • 388
Message 4 of 9
Hi there @Rikkigt4
Thank you so much for your first post to our Community Forums and welcome to the team!
I am so sorry to hear that you are experiencing these slow speeds on your wired connections.
Can you post your Hub status and logs? How to do this;
  • Please go to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode),
  • Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum
Thank you.
Ash_C
jwbull
  • 10
Message 5 of 9
3.0 Upstream channels
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1
32600000
41.020599
5120 KSym/sec
64QAM
5
2
39400000
41.270599
5120 KSym/sec
64QAM
4
3
46200000
41.770599
5120 KSym/sec
64QAM
3
4
53700000
42.770599
5120 KSym/sec
64QAM
2
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
1
US_TYPE_STDMA
0
0
1
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
75178
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
75177
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
TimePriorityDescription
Fri Jun 17 08:18:09 2022
6
CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:18:11 2022
3
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:18:27 2022
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 15; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:18:29 2022
3
Fri Jun 17 08:18:42 2022
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 15; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:18:55 2022
3
Fri Jun 17 08:19:00 2022
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:19:01 2022
3
Fri Jun 17 08:19:15 2022
6
Fri Jun 17 08:19:17 2022
3
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:22:10 2022
3
Ranging Request Retries exhausted;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
3
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:22:19 2022
3
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:23:10 2022
3
Ranging Request Retries exhausted;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
3
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:23:20 2022
3
3
Fri Jun 17 08:23:39 2022
3
3
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=a;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 17 08:24:26 2022
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Mon Jun 20 10:27:56 2022
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 24 19:43:40 2022
3
Sun Jun 26 15:18:38 2022
5
Mon Jun 27 22:12:53 2022
3
Tue Jun 28 16:39:08 2022
4
Wed Jun 29 19:39:59 2022
3
Fri Jul 1 11:49:29 2022
4
Thu Jan 1 00:01:21 1970
3
Mon Jul 4 11:54:49 2022
5
Mon Jul 4 11:55:00 2022
5
RCS Partial Service;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
Mon Jul 4 11:55:36 2022
6
CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
3
Mon Jul 4 11:58:24 2022
5
Wed Jul 6 11:53:51 2022
4
Thu Jul 7 08:01:24 2022
3
Fri Jul 8 09:20:52 2022
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
Fri Jul 8 09:21:02 2022
5
RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri Jul 8 09:21:18 2022
6
Sun Jul 10 05:05:05 2022
4
Sun Jul 10 22:04:54 2022
3
Wed Jul 13 14:59:29 2022
4
Fri Jul 15 06:17:42 2022
3
Speedtest-cli output these are good sometimes I am seeing 0 up and 0.1 down, this is meant to be a 1gbit line
Tue Jul 19 10:40:11 AM BST 2022
50179
Download: 327.97 Mbit/s
Upload: 43.04 Mbit/s
jwbull
  • 10
Message 6 of 9
I am having the same issues.
Thinkbroad band QOS display
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
25
331000000
-2.599998
38.983261
QAM256
25
1
139000000
3.299999
40.946209
QAM256
1
2
147000000
3.099998
40.366287
QAM256
2
3
155000000
3.000000
40.946209
QAM256
3
4
163000000
2.400002
40.366287
QAM256
4
5
171000000
2.099998
40.366287
QAM256
5
6
179000000
1.500000
40.366287
QAM256
6
7
187000000
1.000000
40.366287
QAM256
7
8
195000000
0.900002
40.366287
QAM256
8
9
203000000
0.500000
40.366287
QAM256
9
10
211000000
0.599998
40.366287
QAM256
10
11
219000000
0.799999
40.366287
QAM256
11
12
227000000
0.900002
40.366287
QAM256
12
13
235000000
0.599998
40.366287
QAM256
13
14
243000000
0.200001
40.366287
QAM256
14
15
251000000
0.000000
38.983261
QAM256
15
16
259000000
0.000000
40.366287
QAM256
16
17
267000000
-0.599998
38.983261
QAM256
17
18
275000000
-0.799999
40.366287
QAM256
18
19
283000000
-1.200001
40.366287
QAM256
19
20
291000000
-1.099998
38.983261
QAM256
20
21
299000000
-1.099998
40.366287
QAM256
21
22
307000000
-1.599998
38.983261
QAM256
22
23
315000000
-2.000000
38.983261
QAM256
23
24
323000000
-2.599998
38.983261
QAM256
24
26
339000000
-2.400002
40.366287
QAM256
26
27
347000000
-1.900002
40.366287
QAM256
27
28
355000000
-2.299999
40.366287
QAM256
28
29
363000000
-2.000000
38.983261
QAM256
29
30
371000000
-2.500000
38.605377
QAM256
30
31
379000000
-2.700001
38.983261
QAM256
31
25
Locked
38.983261
0
0
1
Locked
40.946209
0
0
2
Locked
40.366287
0
0
3
Locked
40.946209
0
0
4
Locked
40.366287
0
0
5
Locked
40.366287
0
0
6
Locked
40.366287
0
0
7
Locked
40.366287
0
0
8
Locked
40.366287
0
0
9
Locked
40.366287
0
0
10
Locked
40.366287
0
0
11
Locked
40.366287
0
0
12
Locked
40.366287
0
0
13
Locked
40.366287
0
0
14
Locked
40.366287
0
0
15
Locked
38.983261
0
0
16
Locked
40.366287
0
0
17
Locked
38.983261
0
0
18
Locked
40.366287
0
0
19
Locked
40.366287
0
0
20
Locked
38.983261
0
0
21
Locked
40.366287
0
0
22
Locked
38.983261
0
0
23
Locked
38.983261
0
0
24
Locked
38.983261
0
0
26
Locked
40.366287
0
0
27
Locked
40.366287
0
0
28
Locked
40.366287
0
0
29
Locked
38.983261
0
0
30
Locked
38.605377
0
0
31
Locked
38.983261
0
0
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
33
96
4K
1880
QAM4096
392
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
33
Locked
42
-1.5
390338109
0
Tags (1)
carl_pearce
  • 1.76K
  • 114
  • 377
Super solver
Message 7 of 9
Log your own thread rather than bumping someone elses from months ago!
jwbull
  • 10
Message 8 of 9
Not very Helpful why log a new one when this is the issue and this hasn't be resolved, just add to more of the same on the net 😞
carl_pearce
  • 1.76K
  • 114
  • 377
Super solver
Message 9 of 9
How do you know it's exactly the same issue?
