on 27-07-2023 15:06
I pay for
On average I get 25-50 Mbps. restarted my hub many time and even contacted virgin media by phone.
I have been told I have noise on the line caused by the green box hub network down the street.
Can you get a refund for not providing the service you pay for?
Cable Modem StatusItem Status CommentsAcquired Downstream Channel (Hz) | 202750000 | Locked |
Ranged Upstream Channel (Hz) | 49600000 | Locked |
Provisioning State | Online |
1 | 202750000 | 0 | 38 | 256 qam | 9 |
2 | 138750000 | 1.5 | 37 | 256 qam | 1 |
3 | 146750000 | 2 | 37 | 256 qam | 2 |
4 | 154750000 | 1 | 38 | 256 qam | 3 |
5 | 162750000 | 1.4 | 37 | 256 qam | 4 |
6 | 170750000 | 1.2 | 37 | 256 qam | 5 |
7 | 178750000 | 0.4 | 37 | 256 qam | 6 |
8 | 186750000 | -0.5 | 37 | 256 qam | 7 |
9 | 194750000 | -0.2 | 38 | 256 qam | 8 |
1 | 49600000 | 46 | 5120 | 64 qam | 1 |
2 | 30100000 | 44.5 | 5120 | 64 qam | 4 |
3 | 43100000 | 46 | 5120 | 64 qam | 2 |
4 | 36600000 | 45.8 | 5120 | 64 qam | 3 |
5 | 23600000 | 44.5 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt060-b.cm |
SFID | 19466 |
Max Traffic Rate | 287500061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 19465 |
Max Traffic Rate | 27500061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
27/07/2023 01:29:21 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/07/2023 01:29:19 | Error | DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/07/2023 13:26:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 22:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/07/2023 23:36:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/07/2023 10:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2023 02:26:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/07/2023 07:19:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/07/2023 22:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/07/2023 01:17:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/07/2023 16:14:52 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/07/2023 10:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/07/2023 22:42:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/07/2023 22:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2023 19:41:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2023 15:16:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2023 10:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/07/2023 13:09:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/07/2023 21:04:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/06/2023 22:13:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 27-07-2023 15:18
Have only 9 Downstream Channels connected ?
Hub 3s normally connect 24 Downstream Channels.
on 27-07-2023 15:24
You over wifi or ethernet? that ping looks well high?
27-07-2023 18:16 - edited 27-07-2023 18:17
I also have M250 and been using them close to 4 years now. Your power level look similar to mine
You been asked is the speed you getting via Wi-Fi or wired. If get around 260+ wired then we can safely assume the line is fine and the Wi-Fi is the issue.
I use TP-Link Archer AX55(£75) and get 250+ all over the 3 bed 2 storey house.
on 27-07-2023 18:23
As @Client62 asked, we need to see the rest of your Downstream channel stats. If that is all you have, then there is something badly wrong.
on 27-07-2023 19:03
The OP is fully aware of a noise issue.
That should be reported with estimates to fix via VM's local issues line : 0800 561 0061.
on 28-07-2023 14:26
Hello Joe90galaxy
We're sorry to hear of the issues regarding your broadband speeds, we understand the frustration this can cause and you taking the time to raise this via the forums. Welcome to the community.
From checking the connection and equipment all of the levels appear to be within the ranges and spec's we'd expect to see. We can see the speeds have dropped in recent days, up until the 22nd July the speeds were fine but have dropped over the last few days to 280mbps download and 30mbps upload.
Have you made any changes in that time? Has anything happened during this time with the network at all that you're aware of?
Rob
