  • 7
Message 1 of 13
Not getting expected speed M100
Hi all,
Hoping someone can help. I have M100 broadband, hub3 and connected via ethernet.
Due to past issues my hub is now in modem mode, with a TP-Link Archer router now doing the work. This setup has proved far far more reliable.
All network cables are CAT6.
When I did the above I'd also recently upgraded from a legacy M70 package. I reset the hub3 so a new config file was downloaded.
I get reasonable download speeds of around 100Mb but the upload at it's best is only 5.9 when I was expecting 10. I would like to upgrade to the M200 or higher (they do 1GB now but would need new hub) but reluctant as there maybe an issue limiting my speed.
Looking at other messages I got my router status and the primary downstream service flow max traffic rate is 115000000 and the primary Upstream service flow max traffic rate is 6320000.
Am I right in thinking the configuration file above is limiting the upload speed to around 6MB?
Would another hard reset of the hub resolve this by sending a new config file or is the signal strength or something else the issue?
Full info below:
Router Status
Cable Modem Status
Item
Status
Comments
651000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
Downstream
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
651000000
10.6
38
256 qam
31
Upstream
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
3.754
5120
64 qam
1
2
39400000
3.479
5120
64 qam
4
3
46200000
3.5789999999999997
5120
64 qam
3
4
53700000
3.779
5120
64 qam
2
Router Configuration
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
3254k;fg87dsfd;kfoA,.iyewrkld
SFID
236
Max Traffic Rate
115000000
Max Traffic Burst
10000
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
235
Max Traffic Rate
6320000
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
  • 6.49K
  • 481
  • 851
Hero
Message 2 of 13
Re: Not getting expected speed M100
Have you really only got 1 downstream channel or is it a typo ?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 6.49K
  • 481
  • 851
Hero
Message 3 of 13
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing.
On here click the Link icon (2 link chain)
 In the URL box paste the link you copied and then click OK
Mike Robinson
  • 7
Message 4 of 13
Hi Mike,
Thanks for your help. No sorry the downstream was a typo, I didn't get all the info when I did a cut and paste. My bad.
I will download that monitor and let you know what is shows.
Many thanks.
Info here:
16510000001138256 qam31
246700000011.538256 qam8
347500000010.938256 qam9
448300000010.338256 qam10
549100000010.538256 qam11
64990000001138256 qam12
75070000001138256 qam13
851500000010.438256 qam14
952300000010.338256 qam15
1053100000010.538256 qam16
1153900000011.138256 qam17
125470000001138256 qam18
1355500000010.538256 qam19
1456300000010.538256 qam20
1557100000011.338256 qam21
1657900000011.538256 qam22
175870000001138256 qam23
1859500000010.438256 qam24
1960300000010.438256 qam25
206110000001138256 qam26
2161900000010.938256 qam27
2262700000010.438256 qam28
236350000001038256 qam29
2464300000010.438256 qam30
1Locked38.63440
2Locked38.9760
3Locked38.61030
4Locked38.61180
5Locked38.91190
6Locked38.91190
7Locked38.91170
8Locked38.91300
9Locked38.61740
10Locked38.91560
11Locked38.91790
12Locked38.91960
13Locked38.91850
14Locked38.92740
15Locked38.62420
16Locked38.92950
17Locked38.93060
18Locked38.92760
19Locked38.63530
20Locked38.93460
21Locked38.93580
22Locked38.93690
23Locked38.94670
24Locked38.64000
1603000003.754512064 qam1
2394000003.479512064 qam4
3462000003.5789999999999997512064 qam3
4537000003.779512064 qam2
3ATDMA0000
4ATDMA0000
  • 6.49K
  • 481
  • 851
Hero
Message 5 of 13
With the BQM set it up sooner rather than later and post a link to the live graph using the instruction above.
Mike Robinson
  • 6.49K
  • 481
  • 851
Hero
Message 6 of 13
Your Downstream Power Levels are above max.
Either phone it in or wait on here for one of the VM Staff to pick up the thread, someone should be along within a couple of days.
Don't bump your thread; it doesn't get answered any quicker.
Mike Robinson
  • 1.3K
  • 185
  • 618
Message 7 of 13
@apole55 your downstream power levels are higher than they ideally should be but that in itself isn't the cause of your slow upstream - you got it right in the opening post, your connection has only been provisioned for 6 Meg up.
Personally, I'd wait for a member of the forum team to get to this thread and offer to contact you, I think calling customer services with this one would be a frustrating experience for all!
The high power levels really should be fixed as well (are you close to the street cabinet by any chance?) That'll probably just need a attenuator fitted in line with the hub - but if it's working (and there is a bit of tolerance in the circuitry), then there's no desperate urgency.
  • 14.26K
  • 590
  • 1.37K
Message 8 of 13
You should have 10Mb upload from 70Mb to 100Mb not sure why your not.
  • 6.49K
  • 481
  • 851
Hero
Message 9 of 13
SFID
236
Max Traffic Rate
115000000
Max Traffic Burst
10000
Min Traffic Rate
0
SFID
235
Max Traffic Rate
6320000
Max Traffic Burst
16320
Min Traffic Rate
0
16320
Scheduling Type
BestEffort
The OP's configuration settings are wrong.
Mike Robinson
  • 7
Message 10 of 13
Hi everyone,
Many thanks for taking the time to answer, much appreciated.
I'm not near a street box that I know of, at the very end of the road.
The virgin comes into a junction box on the side of my house, it's a large cable coming in, with several smaller cables, then it looks like there were loads of cables coming out. Previous owner had lines in every room (for TV I think).
I'm not going to open the box as that isn't something I'd be in a position to fix/understand but peering in you can see a connector block with some wires not connected.
Also some of the old wiring coming out has been cut off (before my time).
All that being said there is one connection that goes through the wall and into the lounge to which the hub is connected.
Could it be that the higher than expected power is to do with the original setup which is now not being used. Wondering if an engineer visit would be wise to tidy all the historic stuff up.
When I posted, this part of it had slipped my mind as a potential cause.
Thanks again, will wait for Virgin team to review and advise.
