on 12-05-2023 15:29
I'm on Volt M600, but am getting speedtest results (on mobile, pc ethernet, or laptop wifi) of around 175Mbps.
It's been like this for a year, and didn't realise I was getting the correct dl speed until someone from talktalk came to the door trying to sell their product and said I should be getting more than I am.
How can I get close to the advertised speed?
on 12-05-2023 16:11
Test by wire directly to the hub with a CAT6 cable and boot PC in safe mode with networking
on 12-05-2023 19:33
Use the below site to check the speed to the HUB over the VM network:
https://samknows.com/realspeed/
on 13-05-2023 18:03
on 13-05-2023 18:30
So it's your devices, not the connection over the VM network.
on 13-05-2023 19:37
Is the desktop computer connected via a Powerline adaptor or via WiFi ?
on 13-05-2023 19:51
VM supplied Powerline
on 13-05-2023 20:19
162 Mb/s over a Powerline connection is quite decent.
If we ignored the speed test, I'd expect the PC to work perfectly on every genuine business task.
on 13-05-2023 20:40
@beardedian wrote:VM supplied Powerline
That's your issue.
on 16-05-2023 08:53
Hi @beardedian
Thanks for posting and welcome back to the community. I am sorry to hear of any lower speeds.
I have ran a system diagnostic today and no issues are showing, all your levels are in spec and also no issue with SNR (signal to noise ratio) or congestion.
Please could you run the wired speedtest direct to the router, via laptop/PC at the site above?
For any WiFi issues, please use the Connect App to run a wireless scan in the property, this will help identify and optimise any coverage issues and if any Pods are required, you'll be prompted to order.
Keep us posted.
Best wishes.
