Not getting advertised speed
gs198
Hi there,
I'm on the M600 package but since upgrading to the package 17 months ago my speeds seem to have dropped to around 220-250Mbps.  I've tested using speedtest.net on a couple of computers that are both using gigabit wired ethernet connections.  I was originally getting the advertised speeds so it seems like something has changed with VM since then.  I've copied my router stats below for analysis although they all appear ok based on the pinned guidelines.  My contract expires in just over a week so I'd like this resolved before then as I might as well downgrade my package if I'm not getting what I'm paying for.  Thanks.
12670000002.538256 qam17
21390000004.938256 qam1
3147000000538256 qam2
4155000000538256 qam3
51630000004.938256 qam4
6171000000538256 qam5
71790000004.838256 qam6
8187000000538256 qam7
91950000004.538256 qam8
102030000004.138256 qam9
112110000004.138256 qam10
12219000000438256 qam11
132270000003.938256 qam12
14235000000338256 qam13
152430000002.938256 qam14
162510000002.538256 qam15
172590000002.938256 qam16
18275000000338256 qam18
192830000003.238256 qam19
202910000003.540256 qam20
212990000003.538256 qam21
22307000000340256 qam22
233150000003.438256 qam23
243230000003.738256 qam24
1Locked38.610
2Locked38.660
3Locked38.640
4Locked38.950
5Locked38.650
6Locked38.6130
7Locked38.640
8Locked38.950
9Locked38.960
10Locked38.9190
11Locked38.930
12Locked38.650
13Locked38.650
14Locked38.670
15Locked38.640
16Locked38.9100
17Locked38.960
18Locked38.960
19Locked38.940
20Locked40.370
21Locked38.950
22Locked40.350
23Locked38.950
24Locked38.960
13940000044.8512064 qam4
24620001244.8512064 qam3
35370001246.3512064 qam2
46030002646.8512064 qam1
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;kfoA,.iyewrkldJKDHSUBsgv
SFID15984
Max Traffic Rate690000278
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID15983
Max Traffic Rate44000278
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
5 REPLIES 5
Anonymous
Not applicable
Yup as you say stats seem fine and the speed setting is correct for 600 mbs. Raise a formal complaint as it sounds like you are under the guaranteed speed.
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Try a 60 second factory pinhole reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Setup a BQM to monitor your circuit www.thinkbroadband.com/ping and post a link to the shared live graph.
Once done we can comment.
Also can you run a "pure" speedtest like this.....
_____________________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode”
(https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices are connected Then test speeds at
https://speedtest.samknows.com/
- try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
gs198
Thanks for the replies.
I had to wait until everyone had gone to bed but I've just done the steps advised and it seems like it was something to do with my Netgear R7000 router.  I performed the factory reset on the Superhub and got the full 650Mbps or so with a direct connection to my Mac in both router and modem mode.  I plugged in my router afterwards but for whatever reason it wasn't picking up the WAN connection.  So after a full factory reset on that and a lot of time configuring it again, it's all finally working as expected.
I'm not sure what caused the router to misbehave as it's been going strong for several years and the issue persisted across reboots, but thankfully the factory reset seems to have cured it.
Thank you all again for advice!
Thanks for the update @gs198, and I'm pleased to hear you've been able to find the issue with the speeds.
Do feel free to come back to us if you require any further assistances on your Virgin Media services.
Kindest regards,
David_Bn
