TrojanC
  • 287
  • 31
Superfast
Message 1 of 10
Not getting Gig1 download speed
Gig1 plan
Only getting 250mbps download
42Mbps upload
tech support needed
VM happy camper 🙂 Hub4 NextGen360 Gig1 [modem mode] TP-Link Router + 3x EAP’s
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Not getting Gig1 download speed
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
jamstar2k
  • 41
Message 3 of 10
Take the VM 4.0 hub out of Modem mode and do the test as MikeRobbo suggested directly to the Hub 4.0 - The SamKnows test doesnt work in Modem mode!
The SamKnows test will give you the actaul speed to the Router from Virgin Media and then the speed to you're device over wired connection.
Gareth_L
  • 7.81K
  • 460
  • 867
Message 4 of 10
Hello TrojanC
Quick message to apologise for the low speeds
Just wondering if you have followed the advice that @MikeRobbo gave
Look forward to your reply
Gareth_L
TrojanC
  • 287
  • 31
Superfast
Message 5 of 10
Hello
When Hub4 is (normal) router mode I get
960Mbps Down
42Mbps Up
Ethernet cables are Cat 7
It’s only when in Modem only Mode does the speed drop to *250Mbps Download [*approx]
Uploads Mbps remains the same
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 10
@TrojanC wrote:
Hello
960Mbps Down
42Mbps Up
Is that Modem Mode direct to the Hub or through some third party equipment ?
TrojanC
  • 287
  • 31
Superfast
Message 7 of 10
Hub4 (modem mode) > R600 router > Switch > computer
Anonymous
Not applicable
Message 8 of 10
Since you get full speed with the HUB in router mode you need to investigate the issue with your equipment.
Try one device connected directly connected to the HUB in modem mode to confirm the above.
TrojanC
  • 287
  • 31
Superfast
Message 9 of 10
Hub4 > Tp-link R600 router > computer
same cat 7
252Mbps download
46Mbps Upload
(Router dhcp)
hub4 port 1 out
“Try one device connected directly connected to the HUB in modem mode to confirm the above.”
Cannot connect computer to the Hub4 in modem mode !
‘modem only mode ‘  doesn’t give dhcp
No issues with the R600 Router
Anonymous
Not applicable
Message 10 of 10
What about HUB4 > Computer?
You can use one device with the HUB in modem mode (The HUB must be rebooted with the new device plugged in as it latches onto the MAC address of the last device to be plugged in prior to reboot).
It doesn't matter what it is, Laptop, PC, router, etc.
