Keyboard
  • 24
Message 1 of 5
Not advertised speeds
Over the last two weeks I haven't been getting the download speeds as advertised, but I am getting the correct upload speeds.
I am on a 350Mbps package and getting between 10-40 mbps download. I have tried various different speed test sites, including speedtest.net
I have tried rebooting the router, doing a factory reset, a wired test and wireless with the same results. At random times of the day it seems to go back to its advertised speeds very briefly. Is this due to peak times? I am informed I should be getting at least 150mbps if that was the case. Just to side note, I have made sure all connections are tight from the router and to my outside wall where the data comes into the property.
Is the router at fault here or is there a general issue in the area?
Here are the downstream/upstream levels of the router:
14830000000.737256 qam30
21870000005.340256 qam7
31950000004.840256 qam8
42030000004.540256 qam9
5211000000440256 qam10
62190000004.337256 qam11
72350000004.440256 qam13
82430000003.940256 qam14
92510000003.740256 qam15
102590000003.440256 qam16
112670000003.438256 qam17
122750000003.740256 qam18
132830000003.740256 qam19
14291000000440256 qam20
152990000003.940256 qam21
163070000003.938256 qam22
173150000003.738256 qam23
183230000003.540256 qam24
194430000002.238256 qam25
204510000001.737256 qam26
214590000001.437256 qam27
224670000001.238256 qam28
234750000000.538256 qam29
1Locked37.680
2Locked40.3260
3Locked40.9450
4Locked40.3320
5Locked40.37910
6Locked37.3550
7Locked40.9130
8Locked40.3150
9Locked40.3200
10Locked40.3220
11Locked38.9110
12Locked40.3130
13Locked40.950
14Locked40.3100
15Locked40.390
16Locked38.990
17Locked38.9170
18Locked40.380
19Locked38.690
20Locked37.690
21Locked37.690
22Locked38.670
23Locked38.600
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1393999934.525512064 qam2
2258000094.525512064 qam4
3325999984.525512064 qam3
4461999984.525512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Network log:
13/08/2020 10:22:55Warning!RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xxxx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:22:54Warning!Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:16:14Warning!RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:16:13Warning!Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:16:3Warning!RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:16:1Warning!Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:15:48Warning!RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:15:48Warning!Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:15:25Warning!RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Not advertised speeds
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Roger_Gooner
  • 6.74K
  • 490
  • 1.19K
Legend
Message 3 of 5
Your modem is repeatedly losing network lock. Unless there is a known network fault a tech could be sent round to carry out some checks and if necessary do a hub swap.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
Keyboard
  • 24
Message 4 of 5
Zoie_P
  • 2.94K
  • 137
  • 236
Message 5 of 5
Hi Keyboard thank you for your post sorry to hear you are having issues.
I can take a look for you to see if you have an outage or if you need an engineer. I will pop you over a private message asking for some details. Keep an eye out for the purple envelope 🙂
Zoie
