Not achieving 1Gig after upgrade
Slippy_slaney
I upgraded to the ultimate volt GIG1 package a few months ago. I have a superhub 4 running in modem mode. The wifi being through an ASUS AC1500 mesh. I have my desktop connected via ethernet. Running a speed check on the desktop through ethernet the max download speed has been ~ 550mbit. This is the same speed that I was getting before the upgrade. How do I know whether I have actually been upgraded to 1GiG?
1 ACCEPTED SOLUTION
Accepted Solutions
@Slippy_slaney wrote:
From the link provided
Cheers
Slippy
Seems reasonable then.
I'd still check your Asus for any QOS settings.
Note that you are limited to 940Mbps when connecting your own router due to the 1Gbps Ethernet ports.
9 REPLIES 9
HavencroftKev
Fibre optic
It's worth noting that some equipment isn't capable of receiving 1GB.
carl_pearce
Super solver
Access your Hub on 192.168.0.1, or in this case 192.168.100.1 in modem mode, select 'Check router status' under the login box, then check the 'Configuration' tab.
Should look like this:
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDH
SFID
889
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
1420
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Looks similar but not 100 % same
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
60538
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
60537
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
It's the two numbers I highlighted that matter, so yes, you have been upgraded.
Ensure all QOS options are disabled on the ASUS.
What speed do you get here:
https://proof.ovh.net/
Cheers
Slippy
Cheers
Slippy
Thanks for your help
Cheers
Jeff
These are my figures, I notice the "Primary Downstream Service Flow - Max Traffic Rate" number is different to both the above.
Would my numbers also suggest I am on 1Gbps broadband?
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
SFID
194804
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
194803
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
SFID
194804
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
194803
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
Yes, you are configured for Gig1.
