Ypnos
  • 15
Message 1 of 21
Not a good start (M500)
TL;DR The first and only time I got 500Mbit, was on installation day. Been getting between 46 and 110Mbit ever since. Virgin made it practically impossible to get in touch.
First time in my life went with Virgin Media, not at all impressed so far.
- Getting through on the phone takes 20+ minutes
- Chat has been switched off
- There is no email address to send emails to
- Complaints have been switched off (attached "oops" message") for days
- Even twitter messages go unanswered
So, the engineer turned up, fitted the line and set the Superhub up for Modem Only operation, so I can use my existing Asus router. Did a speed test, got 510Mbit - lovely. did a few more speed tests over the evening, got 400ish Mbits. Fine.
Following day, around 10am speedtests showing around 200mbit! Carried on testing and have been horrified to find that I cannot get anything above 110Mbit. Last night at 9pm I was getting 46Mbit.
Tried several WiFi devices and 3 separate ethernet devices (2 laptops and a dekstop), all showing the same results. I'm an IT engineer of 20+ years, so this stuff is my bread and butter. Very disappointed, but I can't say I wasn't warned about how poor VM is...oops.JPG
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 21
Re: Not a good start (M500)
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Ypnos
  • 15
Message 3 of 21
Thanks, I will do this tonight
Ypnos
  • 15
Message 4 of 21
Here is the graph. In typical Murphy's law fashion, speed was OK last night (though considerably less than 500Mbit)
Graph
Buffer6
  • 11.2K
  • 93
  • 632
Hero
Message 5 of 21
You need to set up another BQM as the one you're showing is not responding
Ypnos
  • 15
Message 6 of 21
Hi, it was the firewall blocking ping requests - here's the latest graph
https://www.thinkbroadband.com/broadband/monitoring/quality/share/83d0e3c1fd832fcfc11fdb589512d2c6d1...
Here is my speedtest, on ethernet
https://www.thinkbroadband.com/_assets/speedtest/button/1602432690560336555.png
Pretty poor really.
Anonymous
Not applicable
Message 7 of 21
Your BQM is what I consider perfect.
I have a feeling the 100Mbps limit is related to:
  1. Bad ethernet cable.
  2. QOS settings on your Asus Router.
  3. Faulty HUB.
I'm betting on 1 or 2.
Ypnos
  • 15
Message 8 of 21
I get 100Mbit-ish on all devices, whether wired (different cables) or wifi and I had already heard of the QOS thing with the Asus router, so I had switched it off in advance of VM install.
I don't know if the hub is faulty or not, because I have seen the setup do 400 to 500mbit, just rarely.
My guess is that because our street only got cabled a few months ago, the exchange will be overloaded as there has been a huge uptake.
Andrew-G
  • 7.03K
  • 1.22K
  • 3.07K
Message 9 of 21
@Ypnos My guess is that because our street only got cabled a few months ago, the exchange will be overloaded as there has been a huge uptake.
Nope.  Your BQM is excellent, and overloading (over-utilisation in VM-speak) would show up very, very clearly as a sea of blue and yellow squiggles, but reasonable latency between 1am and 7am.
Andrew-G
  • 7.03K
  • 1.22K
  • 3.07K
Message 10 of 21
What speeds do you get with the hub in router mode?  I know that you want and expect to have it working properly in modem mode (I do this too) but let's see if we can isolate the problem a bit more.
