AR619
  • 6
Message 1 of 12
Not Reaching Max Speeds with Ethernet & Slower speeds in general
Hi, so I have the
Why can't I unlock that full ethernet speed (or even close to that) on my devices (PC and PS4)? Last time I checked, a couple of months ago, a speed test using WiFi right next to the router got me around that 110 down speed and 10 up - go into the kitchen and I'm down to like 20 or 30 down.
Upstairs, even with a range extender, I can get a max of 20 down with wifi. And one room upstairs pretty much has zero signal.
jb66
  • 12.14K
  • 899
  • 1.75K
Message 2 of 12
Re: Not Reaching Max Speeds with Ethernet & Slower speeds in general
That's becuase powerlines and wireless extenders suck, you need to invest in better solutions like a mesh system if you want great speeds all over your home
AR619
  • 6
Message 3 of 12
I tried ethernet without powerline adapters and I still got the same results, less than 60 down. You're telling me I can't fulfill the max speed without a mesh system?
jb66
  • 12.14K
  • 899
  • 1.75K
Message 4 of 12
I'm saying it's normal that using an extender gives poor results and the same goes for powerlines and doing speedtests via a games console.
If you directly plug in a laptop to the hub I would expect maximum speeds
AR619
  • 6
Message 5 of 12
I did directly plug a laptop to the router and I got around the same speeds (not an extender or powerline adapter). Mind you I did have to use a USB-C to RJ45 Adapter because the laptop didn't have an ethernet port.
gary_dexter
  • 30.36K
  • 1.88K
  • 4.03K
Message 6 of 12
Could be the adaptor then.
What spec is the Ethernet cable?
RedGooner
  • 1.91K
  • 69
  • 255
Super solver
Message 7 of 12
Are you sure your extenders have a 1Gb port on them, from what i am reading it looks like they are 100Mb. So 60Mb is about the correct speed you will get.
I say this to most people on VM, the SH is useless. Get your own router and put the SH into modem mode.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
AR619
  • 6
Message 8 of 12
Cat 5e I believe. But even when powerline adapters aren't used and when the cable goes directly to the Router hub the speeds stay the same
Tags (1)
gary_dexter
  • 30.36K
  • 1.88K
  • 4.03K
Message 9 of 12
It could be the adaptor then.
What make and model is it?
AR619
  • 6
Message 10 of 12
It's a TP Link Gigabit Powerline adapter. Getting close to 80 down now after I bought this new Gigabit adapter - TP-Link TL-PA717.
https://www.amazon.co.uk/gp/product/B07G37DJ8R/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
