Afaber
No upload speed
I have 100+ download speed and 0.1 upload speed. How can I fix this as I should have 20 upload?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: No upload speed
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: No upload speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
