SteveH
  • 149
  • 25
Up to speed
Message 1 of 8
No speed
Since last night, my 200 Meg connection has become 20 Meg down and .05 Meg up, eg completely unusable. Done diagnostics, checked connections, rebooted sh3, and its not my end. What's happening VM?  SteveH
harveyp2
  • 8
Message 2 of 8
Re: No speed
Join the club! See my post. This morning VM cancelled my scheduled service call and finally, after a week admitted they have a network problem. If its not fixed soon I will be in an argument as to cancelling my contract and going to another provider.
SteveH
  • 149
  • 25
Up to speed
Message 3 of 8
Re: No speed
Same here. Gnetworks have just cabled my street with ftth, 300meg for 37.00 Starting to look very tempting...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 8
Re: No speed
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 8
Re: No speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 8
Re: No speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
SteveH
  • 149
  • 25
Up to speed
Message 7 of 8
Re: No speed
Thanks for the screenfuls (on a mobile) of c&p, but I've been a customer since broadband was a thing. Router's been rebooted etc, no change. Haven't posted diags as the status line already accepts its VMs fault. I'm sure if VM want diags they will ask, thanks.
SteveH
  • 149
  • 25
Up to speed
Message 8 of 8
When is this interference problem in parts of London gonna be sorted?
My Internet is now completely unusable. This simply isn't good enough. I will be wanting a reduction of my bill for this. Issue confirmed as VM's by status test, so no useful help please robbo. Thanks.
