Wilson101
Message 1 of 10
No Wolverhampton hub on speed nest double latency
Hi there.
we’ve been unable to connect to the Wolverhampton virgin media server for over a week. It does not exist on any speed tests anymore. The result is we have double the normal latency and are having packet loss issues.
does anybody know.
A. What the issue is.
B. If and when it will be rectified.
c. Is this a joke for premium service ?
thanks guys any info warmly received.
time to look into new ISPs now fibre is rolled out round here I think.
stay safe.
wilson.
Andrew-G
  • 6.13K
  • 1.08K
  • 2.6K
Message 2 of 10
Re: No Wolverhampton hub on speed nest double latency
VM have discontinued the Ookla Speedtest servers as the Hub 3 and 4 now both have SamKnows speed test functionality in the firmware.  That built in capability will only work if you're using the hub in router mode, and you'll have to have a delve in the settings to find out where it is - I don't know because my Hub 3 is in modem mode.
But if you're seeing packet loss issues, that's most likely your cable connection, rather than Speedtest routing, so consider posting your hub's status data here (as text, not screenshots) and somebody will take a look at it.
Wilson101
Message 3 of 10
Thanks man
Graham_A
  • 16.14K
  • 2.26K
  • 6.9K
Message 4 of 10
@Wilson101
Probably worth adding that, whilst I understand that VM intend to make the Samknows realspeed test available via the Hub3, the firmware to support this has not yet been rolled out.
It is available if using a Hub4 in router mode.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
wiggles
  • 164
  • 16
Dialled in
Message 5 of 10
@Wilson101 wrote:
Hi there.
does anybody know.
stay safe.
wilson.
https://samknows.com/realspeed/ is the tests for Hub 4 I use that to check my incoming from the wall as it will do that direct to the hub 4, as for everyday tests I use http://ovh.net/ to do my tests as the OVH/Nperf servers are far superior to Ookla IMHO
3rd Line IT Support Staff (non VM), Avid Gamer, Can cook toast and not burn it
My Broadband Ping - Home VM
cje85
  • 2.63K
  • 169
  • 693
Trouble shooter
Message 6 of 10
@Wilson101 wrote:
Hi there.
does anybody know.
SpeedTest only checks your speed/latency to the server you're using to test. Virgin Media's own servers would give the best possible results but other servers give a more realistic result of your connection to the wider internet.
The removal of the Virgin Media servers won't have any impact on your actual connection,  only the speed test results.
Sasha_W
  • 962
  • 39
  • 74
Message 7 of 10
Morning @Wilson101
Welcome to the forum community and thanks for posting this on here, sorry to hear you're having some issues with your speeds and latency but we can look into this for you.
Are these speeds low on all devices or is it just some that are experiencing these speeds?
I know this may sound obvious, but have you checked our service status page for any outages which could result to decrease in speeds?
Have you also carried out a pin  hole reset of your hub to see if this makes a difference?
Please do let us know so we can check further into your account for you.
Sasha - Forum Team
Wilson101
Message 8 of 10
Hi there. Thank u for getting back to me.
yes I’ve done a pinhole reset.
I’m currently getting about 30mbps download.
a few weeks ago was getting 380!!!
best wishes
Wilson.
Sasha_W
  • 962
  • 39
  • 74
Message 9 of 10
Thanks for getting back to me @Wlson101,
I am just going to pop you over a PM so we can look at your account more closely if that's okay.
You should see a purple envelope at the top of your page, if you click on that, it will take you to PM's. 🙂
Sasha - Forum Team
Sasha_W
  • 962
  • 39
  • 74
Message 10 of 10
Hi @Wilson101
Sorry for the spam in messages, but I have booked you a technician to get this sorted for you.
I have PM'd you over the details and if you wish to change or cancel this, you can via your virgin media account on your order section.
If you do also have any further questions, please feel free to message me back 🙂
Have a fab day and enjoy the sunshine 🙂
Sasha - Forum Team
