No Virgin Media wall socket at installation - M100 Fibre Broadband
tolga
I've just moved into a property and I'm trying to set up my Virgin M100 Fibre Broadband. I'm at the stage where I need to plug the isolator cable into the Virgin Media wall socket. However, I do not have any of the specified wall sockets available. I was told when purchasing the broadband that fibre was available here and already in use, so am wondering if I'm missing something.
See attached photo of the sockets I have available. Please help as I have no internet and I need it for work urgently. Thank you!
WhatsApp Image 2022-08-03 at 11.03.10 PM.jpegWhatsApp Image 2022-08-03 at 11.03.05 PM.jpeg
1 ACCEPTED SOLUTION
Accepted Solutions
I guess I should have just waited, after 24 hours the internet became available itself
3 REPLIES 3
nodrogd
The isolator cable should push over the spare F-connector port on the splitter you have in your hand. Don’t worry that it is not a threaded plug. These are designed to push over the screw thread on the socket.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
Matthew_ML
Hey tolga, thank you for reaching out and a warm welcome to the community. I am sorry to see you are struggling to get your equipment up.
How have you gone on with the tips nodrogd advised has this been any help?
Please do let me know and we can look into if you are still struggling. Thanks
Matt - Forum Team
New around here?
