Fedup01
  • 25
Message 1 of 7
No Upload Speed, or very low.
Ok.
So I posted yesterday, because we realised that the wi-fi was turning itself back on, each time I turned it off. Later that day, we found we could not access Netflix, Amazon or you tube on the TV. I then used the Computer/Desktop PC and found I could not connect to e-mail, banks, Steam / Xbox, etc. Steam I understand said repeatedly the connection was unstable, and issued time out bans, for the constant disconnections. (This is all Ethernet, not Wi-fi to devices).
The hub said “Partial service (DS only)”. I rebooted and reset the Hub 3. I checked all the cables. The set-up has been in place for nearly 04 years, and where the hub is placed means no one can get near the cables in general.
I ran a speed test last night (https://www.speedtest.net). It said the upstream was zero, or at best between 0 and 1 (mostly I get “Upload test error”. It does randomly get back up to say 7-8, but only for short durations making it useless. (Whereas it was 20 before). The downstream is dropping frequently to 20-40, but can get back to the normal 80-120. (We pay for 200). The ping is shifting from 20-250, (normally stable around 15-40).
The computer and TV connection to the internet are unusable now on this basis. I think the inability to turn off wi-fi could well relate to the zero up steam issue. The bank and online supermarket wanted me to change password after a few failed attempts where it timed out. I could then not change the password, I assume because of the lack of up-stream. I couldn’t change or cancel the shopping order for today. When I ran the system check on VM, the first 02 times it failed to complete (just spun around for over 30 minutes). It then passed with no errors in a few minutes. On another try it  ended with a yellow box, that said there were Network errors. I could not tell though, if that meant mine or Virgin Media.
So, yesterdayI reboot, reset, factory reset, multiple times. I checked all the cables for connection and tightness. I put the hub in modem mode. It made no difference. I then reset with a pin to factory settings, which is where it now is. I also as a trial, removed the PC cables from the rooter. The problem persisted on the TV. I then removed the TV and had issues on the PC. I changed the cables around and swapped the cables otthe TV and PC to no change.
I am hoping it’s a temporary or local issue. Here are the logs from last night, hours after the reset, reboot, pin reset, etc. (Sometimes I can’t log into the hub or run diagnostics).
As a random note, if I refresh the connected devices, the number can change from 1-3. (Even though all 3 items are connected at the time). Sometimes the PC is not there (even as I am looking at the hub data on it), Sometimes the TV is gone, (but on), and sometimes the TiVo box.
I am housebound and don't have a mobile. My partner works from home, but cannot access her employer.
Time
Priority
Description
24/08/2021 23:14:24
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2021 23:11:58
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2021 23:11:56
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2021 23:11:9
Warning!
24/08/2021 23:10:14
notice
24/08/2021 23:05:8
critical
24/08/2021 22:58:40
notice
24/08/2021 22:56:22
critical
24/08/2021 22:54:4
Warning!
24/08/2021 22:48:7
critical
24/08/2021 22:38:21
Warning!
01/01/1970 00:01:37
critical
24/08/2021 22:30:17
critical
24/08/2021 22:29:55
Warning!
24/08/2021 22:29:12
critical
24/08/2021 22:20:1
Warning!
24/08/2021 22:19:39
critical
24/08/2021 22:18:23
Warning!
24/08/2021 22:17:12
critical
24/08/2021 22:15:27
Warning!
This seems to be typical over the hours. Its the same sort of thing this morning. What should i do next?
Fedup01
  • 25
Message 2 of 7
Re: No Upload Speed, or very low. (Hub data)
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
51
5120
64 qam
5
2
53699981
51
5120
64 qam
2
3
46200000
51
5120
32 qam
3
4
39399961
51
5120
64 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-3.7
37
256 qam
1
2
147000000
-3.9
37
256 qam
2
3
155000000
-5.2
37
256 qam
3
4
163000000
-5.5
37
256 qam
4
5
171000000
-5.2
37
256 qam
5
6
179000000
-5
37
256 qam
6
7
187000000
-5.2
37
256 qam
7
8
195000000
-5.7
37
256 qam
8
9
203000000
-6
37
256 qam
9
10
211000000
-5.9
37
256 qam
10
11
219000000
-5.7
37
256 qam
11
12
227000000
-6.2
37
256 qam
12
13
235000000
-6.9
37
256 qam
13
14
243000000
-7.5
37
256 qam
14
15
251000000
-7
37
256 qam
15
16
259000000
-6.2
37
256 qam
16
17
267000000
-5.7
37
256 qam
17
18
275000000
-6
37
256 qam
18
19
283000000
-6.4
37
256 qam
19
20
291000000
-6.9
37
256 qam
20
21
299000000
-6.7
37
256 qam
21
22
307000000
-6
37
256 qam
22
23
315000000
-5.2
37
256 qam
23
24
323000000
-4.7
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
51915
107970
2
Locked
37.6
105846
11534
3
Locked
37.3
66826
61029
4
Locked
37.3
54227
80359
5
Locked
37.6
12685
2495
6
Locked
37.6
1342
759
7
Locked
37.6
4925
2011
8
Locked
37.3
3929
4071
9
Locked
37.6
3892
2830
10
Locked
37.6
1569
808
11
Locked
37.6
2513
797
12
Locked
37.6
4622
2338
13
Locked
37.6
4114
2581
14
Locked
37.3
3060
58
15
Locked
37.3
290
17
16
Locked
37.3
2667
390
17
Locked
37.3
2268
1815
18
Locked
37.6
3891
1080
19
Locked
37.3
582
0
20
Locked
37.3
165
0
21
Locked
37.3
93
0
22
Locked
37.6
58
0
23
Locked
37.6
201
0
24
Locked
37.6
583
2
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID
134630
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
134629
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Fedup01
  • 25
Message 3 of 7
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
51
5120
64 qam
5
2
53699981
51
5120
64 qam
2
3
46200000
51
5120
32 qam
3
4
39399961
51
5120
64 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-3.7
37
256 qam
1
2
147000000
-3.9
37
256 qam
2
3
155000000
-5.2
37
256 qam
3
4
163000000
-5.5
37
256 qam
4
5
171000000
-5.2
37
256 qam
5
6
179000000
-5
37
256 qam
6
7
187000000
-5.2
37
256 qam
7
8
195000000
-5.7
37
256 qam
8
9
203000000
-6
37
256 qam
9
10
211000000
-5.9
37
256 qam
10
11
219000000
-5.7
37
256 qam
11
12
227000000
-6.2
37
256 qam
12
13
235000000
-6.9
37
256 qam
13
14
243000000
-7.5
37
256 qam
14
15
251000000
-7
37
256 qam
15
16
259000000
-6.2
37
256 qam
16
17
267000000
-5.7
37
256 qam
17
18
275000000
-6
37
256 qam
18
19
283000000
-6.4
37
256 qam
19
20
291000000
-6.9
37
256 qam
20
21
299000000
-6.7
37
256 qam
21
22
307000000
-6
37
256 qam
22
23
315000000
-5.2
37
256 qam
23
24
323000000
-4.7
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
51915
107970
2
Locked
37.6
105846
11534
3
Locked
37.3
66826
61029
4
Locked
37.3
54227
80359
5
Locked
37.6
12685
2495
6
Locked
37.6
1342
759
7
Locked
37.6
4925
2011
8
Locked
37.3
3929
4071
9
Locked
37.6
3892
2830
10
Locked
37.6
1569
808
11
Locked
37.6
2513
797
12
Locked
37.6
4622
2338
13
Locked
37.6
4114
2581
14
Locked
37.3
3060
58
15
Locked
37.3
290
17
16
Locked
37.3
2667
390
17
Locked
37.3
2268
1815
18
Locked
37.6
3891
1080
19
Locked
37.3
582
0
20
Locked
37.3
165
0
21
Locked
37.3
93
0
22
Locked
37.6
58
0
23
Locked
37.6
201
0
24
Locked
37.6
583
2
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID
134630
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
134629
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
BestEffort
sophist
  • 2.7K
  • 433
  • 717
Trouble shooter
Message 4 of 7
@Fedup01 wrot
The log doesn't look particularly healthy, can you also post teh upstream/downstream data from the same place that you got the log from..
edit. weird, i didn't see the second post with all of hte data..
anyways, downstream power levels are (i think) right on the cusp of being too low. one of your upstream channels is only negotiating a QAM of 32 - should all be at 64. upstream power levels are also borderline unacceptable too..
you also have a bunch of post-rs errors on the downstream channels.
from the log, it looks like your modem is losing connection to the CMTS.
suspect that this will need an engineer visit.  VM should be along within a couple of days to comment.
Tom_F
  • 4.22K
  • 250
  • 536
Message 5 of 7
Hi Fedup01, thanks for posting.
Sorry about the issues you've had with your connection. To confirm what sophist already advised it's clear from here that there are issues that will require the attention of an engineer, please get back to me via PM and we'll be able to get that arranged for you.
Tom
Fedup01
  • 25
Message 6 of 7
Apologies for the delay in my reply. Things seem to have normalised back to normal. I wanted to wait and see if they would stay that way for a while. Yesterday morning when i sent the second post with my stream data to the forum, it timed out. I then got a message saying i was banned for the day from the board for sending too many messages in rapid series. It turned up about 4 hours later on the forum.  : )
We went to my brothers house to access various things for work. We got back around 16:30 to find everything seemed to be ok again. The logs were clear from around 16:00 p.m.. They stayed clear until around 18:30 when everything suddenly dropped out again, and the Sync and time out errors were there on the log as before (e.g. Upload had dropped from 21 mbs ,to zero or 0.1). We could again not access things, and this was the case until around 19:00 when suddenly it all went back to working. It has been working since 19:30, and seems to be fine at the time of writing this.  Hopefully it will stay that way.
Many thanks to those who took the time to reply. I appreciatre the help and advice.
The 18:30 event on the network log. There has been nothing on it since, and we have not touched or changed anything since yesterday morning.
Time
Priority
Description
25/08/2021 18:48:34
notice
25/08/2021 18:47:58
Warning!
25/08/2021 18:47:7
critical
25/08/2021 18:39:36
Warning!
25/08/2021 18:39:34
critical
25/08/2021 18:39:29
Warning!
25/08/2021 18:39:20
critical
25/08/2021 18:39:14
Warning!
25/08/2021 18:39:14
critical
25/08/2021 18:39:10
Warning!
25/08/2021 18:39:9
critical
25/08/2021 18:32:21
Warning!
25/08/2021 18:32:21
critical
25/08/2021 18:32:16
Warning!
25/08/2021 18:32:13
critical
25/08/2021 18:32:11
Warning!
25/08/2021 18:32:10
critical
25/08/2021 18:32:8
Warning!
25/08/2021 18:32:8
critical
25/08/2021 18:32:8
Warning!
Tom_F
  • 4.22K
  • 250
  • 536
Message 7 of 7
@Fedup01, really glad to hear things have improved now thanks for updating the thread,  please don't hesitate to get back in touch if any more problems arise.
Tom
