RichardMacc
  • 17
Message 1 of 28
No Ranging Response received problem and loss of wifi bands DHCP
HI, 1st post on here, but getting very frustrated about the wifi. I have seen several posts about the "No Ranging Response received" which seems to be an issue with my router and also the DHCP renew error. Please see below the log from the router today. I have had to move all the house to TP plug units so they can access the router. Not ideal when 2 home schooling and 2 trying to run a business. Any help appreciated and if I need to ring virgin, I will
Time
Priority
Description
11/01/2021 10:55:29
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37
critical
No Ranging Response received - T3 time-out;CM-MAC=********;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 01:22:52
notice
SW download Successful - Via NMS
11/01/2021 01:19:35
notice
SW Download INIT - Via NMS
10/01/2021 17:55:46
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=****:16:53;CMTS-MAC=********-QOS=1.1;CM-VER=3.0;
07/01/2021 19:12:37
critical
06/01/2021 02:25:13
Error
04/01/2021 20:29:2
critical
02/01/2021 19:30:27
Error
30/12/2020 05:12:29
critical
29/12/2020 20:20:12
Error
28/12/2020 02:22:52
critical
26/12/2020 08:20:12
Error
23/12/2020 23:42:25
critical
22/12/2020 20:20:12
Error
21/12/2020 18:12:49
critical
19/12/2020 08:20:12
Error
17/12/2020 04:33:15
critical
15/12/2020 20:20:12
Error
13/12/2020 09:45:51
critical
Not sure there are any other logs...
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 28
Re: No Ranging Response received problem and loss of wifi bands DHCP
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream and Configuration Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 28
RichardMacc
  • 17
Message 4 of 28
Hi Mike, please find below the info requested. I did try and I hit the limit, so hence putting the 1st part up.
12587500000.538256 qam16
21387500001.738256 qam1
31467500001.538256 qam2
41547500001.438256 qam3
51627500001.238256 qam4
61707500001.538256 qam5
71787500001.538256 qam6
81867500001.438256 qam7
91947500001.438256 qam8
10202750000138256 qam9
1Locked38.660
2Locked38.9160
3Locked38.9200
4Locked38.9320
5Locked38.9510
6Locked38.9130
7Locked38.9150
8Locked38.9950
9Locked38.9380
10Locked38.9410
11Locked38.6110
12Locked38.6100
13Locked38.6180
14Locked38.9210
15Locked38.6190
16Locked38.670
17Locked38.6130
18Locked38.960
19Locked38.9110
20Locked38.9140
21Locked38.670
22Locked38.6270
23Locked38.6150
24Locked38.6140
RichardMacc
  • 17
Message 5 of 28
15370000048.3512064 qam8
24620000046.8512064 qam5
33940000046.5512064 qam6
43260000045.8512064 qam7
1ATDMA00110
3ATDMA0000
4ATDMA0000
RichardMacc
  • 17
Message 6 of 28
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID162292
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID162291
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 28
Can you repost both tables from the Downstream please, you are missing 14 Channels from the Power Levels table.
RichardMacc
  • 17
Message 8 of 28
112107500000.938256 qam10
122187500000.738256 qam11
132267500000.438256 qam12
142347500000.538256 qam13
152427500000.438256 qam14
162507500000.538256 qam15
172667500000.538256 qam17
182747500000.538256 qam18
192827500000.538256 qam19
202907500000.438256 qam20
212987500000.538256 qam21
223067500000.238256 qam22
233147500000.538256 qam23
243227500000.738256 qam24
RichardMacc
  • 17
Message 9 of 28
Here you go
1Locked38.660
2Locked38.9160
3Locked38.9200
4Locked38.9320
5Locked38.9510
6Locked38.9130
7Locked38.9150
8Locked38.9950
9Locked38.9380
10Locked38.9410
11Locked38.6110
12Locked38.6100
13Locked38.6180
14Locked38.9210
15Locked38.6190
16Locked38.670
17Locked38.6130
18Locked38.960
19Locked38.9110
20Locked38.9140
21Locked38.670
22Locked38.6270
23Locked38.6150
24Locked38.6140
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 28
Your Hub data is all good, just need the link to your BQM now.
