Harrison09
  • 11
New installation, speed varying.
Hi there, I had my new 500 fibre fitted today and the first hour or so it was at around 350-410mb download and 40 upload, but now when I'm running tests on my PS4 and PC they are both showing it as around 40 download and 9 upload, I tested it earlier on the PS4 by downloading a game and it was very fast, now the same game it says it will take 3 hours, is this just part of the normal stabilization period? I was told the speeds would just continue to get faster by the engineer.
Cheers.
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Re: New installation, speed varying.
Hello,
If you have taken a package out you will notice that speeds will be different for the first 30 days as this is the time frame that things will start to settle down.
Can you go to 192.168.0.1 and post your Modem Stats for us to see just in case there is another problem.
