wafubloke
Message 1 of 5
New install- how long for max speed?
I had my install earlier today and am currently getting 46Mbps. I get it might take a short time to get to max speed, but how long does this usually take?
I have signed up for the 350Mbps service.
Hub 3 set to Modem mode and connected via ethernet to Mac.
Many thanks
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Message 2 of 5
Re: New install- how long for max speed?
Hello
You should be getting max speed from install with cable it is straight away, when you run a speedtest.net what speeds are you getting.
Regards Mike
wafubloke
Message 3 of 5
Ping 7ms
Download 45.56Mbps
Upload 17.50Mbps
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 4 of 5
Modem mode with your own router installed?
What speed do you get wired direct to the hub with nothing else in between?
wafubloke
Message 5 of 5
I rebooted my Dream Machine and it now works.
Many thanks guys. Now have 389Mbps, sweet!
