Bingy27
  • 8
Message 1 of 10
New customer on 108mb and speed dropped to 15mb and below
so I’ve had virgin going for less than a month and speeds and connectivity were first rate for the first week or so, lately they have been between 5-15mb and I can barely use internet on any devices. When I do get connected it drops out constantly.
tried to call virgin but got reverted back here.
have done multiple resets inc factory and nothing is helping fix this issue.
Please help 😞
Bingy27
  • 8
Message 2 of 10
Re: New customer on 108mb and speed dropped to 15mb and below
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1331000000538256 qam25
22030000008.140256 qam9
3211000000838256 qam10
42190000007.540256 qam11
52270000007.338256 qam12
6235000000738256 qam13
72430000006.938256 qam14
82510000006.538256 qam15
92590000006.538256 qam16
102670000006.138256 qam17
112750000006.340256 qam18
12283000000640256 qam19
132910000005.838256 qam20
142990000005.938256 qam21
153070000005.638256 qam22
163150000005.538256 qam23
173230000005.338256 qam24
183710000004.538256 qam26
193790000004.838256 qam27
203870000004.638256 qam28
213950000004.438256 qam29
22403000000438256 qam30
234110000004.438256 qam31
244190000004.438256 qam32
1Locked38.9380
2Locked40.3400
3Locked38.9150
4Locked40.3220
5Locked38.9340
6Locked38.9200
7Locked38.9240
8Locked38.9290
9Locked38.9260
10Locked38.6320
11Locked40.3250
12Locked40.3250
13Locked38.6520
14Locked38.9310
15Locked38.9260
16Locked38.9420
17Locked38.6300
18Locked38.9130
19Locked38.9510
20Locked38.9210
21Locked38.6960
22Locked38.9350
23Locked38.9370
24Locked38.9130
Bingy27
  • 8
Message 3 of 10
16030000050512064 qam1
23940000049.8512064 qam4
34620000049.8512064 qam3
45370000050512064 qam2
1ATDMA0030
2ATDMA0010
3ATDMA0000
4ATDMA0000
Bingy27
  • 8
Message 4 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID290188
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID290187
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
Bingy27
  • 8
Message 6 of 10
20/11/2020 07:52:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 02:56:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 19:20:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 07:01:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 11:59:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 16:31:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 09:27:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:09:23noticeSW download Successful - Via NMS
06/11/2020 01:08:0noticeSW Download INIT - Via NMS
05/11/2020 00:38:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 15:28:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 12:38:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 13:32:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:23:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:23:1Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 00:38:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 06:41:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 20:06:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 16:19:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Bingy27
  • 8
Message 7 of 10
MY BQM
I set one up when I got the broadband going so should be my full history
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 10
What is your connection like using a direct connection with a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Bingy27
  • 8
Message 9 of 10
thanks Mike Robbo for such a quick reply! Really grateful for any help.
Bingy27
  • 8
Message 10 of 10
Ok, will get this done ASAP and post back results.
