TiredVery
  • 15
Message 1 of 22
New Hub, now speed is only 2mbps.
I had an intermittent connection so Virgin sent me a new Hub.
Installed it today, and now instead of 108mbps, I'm getting a speed of 2mbps.
(Speed might briefly be full speed after a reset, but within 5 minutes it's dropped to 2mbps again).
What might cause this?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 22
Re: New Hub, now speed is only 2mbps.
How are you testing, over Wi-Fi or ethernet cable connected device ?
TiredVery
  • 15
Message 3 of 22
I'm testing both with Ethernet and over WiFi.
For the first few minutes it reports a speed of 108mbps, then it drops to 1-2mbps.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 22
OK.
From now on during testing and connecting please stick with an ethernet connected device.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
TiredVery
  • 15
Message 5 of 22
Thanks Mike Robbo.
Here's my Live Graph:
Clicky Hyperlink to Live Graph
CHECK ROUTER STATUS RESULTS:
11867500004.638256 qam7
21387500004.637256 qam1
3146750000438256 qam2
41547500003.738256 qam3
5162750000438256 qam4
61707500004.438256 qam5
71787500004.538256 qam6
81947500004.838256 qam8
92027500004.638256 qam9
102107500004.638256 qam10
112187500004.538256 qam11
122267500004.838256 qam12
132347500004.838256 qam13
142427500004.438256 qam14
152507500003.738256 qam15
162587500003.938256 qam16
172667500004.938256 qam17
18274750000538256 qam18
19282750000540256 qam19
20290750000538256 qam20
212987500005.138256 qam21
223067500005.540256 qam22
233147500005.338256 qam23
243227500005.138256 qam24
1Locked38.699120
2Locked37.6101185
3Locked38.696178
4Locked38.694151
5Locked38.998144
6Locked38.6103142
7Locked38.993129
8Locked38.983120
9Locked38.964125
10Locked38.673111
11Locked38.664119
12Locked38.669113
13Locked38.965117
14Locked38.978104
15Locked38.663108
16Locked38.658109
17Locked38.665102
18Locked38.656109
19Locked40.352115
20Locked38.960102
21Locked38.653101
22Locked40.36995
23Locked38.957101
24Locked38.96191
1462000005.1512064 qam1
2326000005.1512064 qam3
3394000005.1512064 qam2
3ATDMA0000
TiredVery
  • 15
Message 6 of 22
BQM Link:
BQM Hyperlink Clicky
12/09/2020 08:52:46Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:51:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:50:17Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:50:17Warning!Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:19Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:43:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:42:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 08:42:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
TiredVery
  • 15
Message 7 of 22
I notice the forum's starred out some of the numbers above. Hopefully it's still intelligible?
TiredVery
  • 15
Message 8 of 22
1Locked38.699120
2Locked37.6101185
3Locked38.696178
4Locked38.694151
5Locked38.998144
6Locked38.6103142
7Locked38.993129
8Locked38.983120
9Locked38.964125
10Locked38.673111
11Locked38.664119
12Locked38.669113
13Locked38.965117
14Locked38.978104
15Locked38.663108
16Locked38.658109
17Locked38.665102
18Locked38.656109
19Locked40.352115
20Locked38.960102
21Locked38.653101
22Locked40.36995
23Locked38.957101
24Locked38.96191
TiredVery
  • 15
Message 9 of 22
3ATDMA0000
jem101
  • 1.71K
  • 236
  • 800
Message 10 of 22
@TiredVery you have a cable fault, there was probably nothing wrong with the original hub. You might try checking all the cable joints you can get to and see if they are loose or obviously damaged. Failing that you will need an engineer visit to track it down and fix.
