pmc815234
  • 26
Message 1 of 28
New GIG1 same speed as M500
I signed up for 1 GPS which has just become available in Belfast and I set up my new Hub 4 on Wednesday. I am using it in Modem mode with an ASUS GT AX-11000 router. I have tested the speed both WiFi and through my Devlo Magic 2 Powerline Adaptors (up to 2400mps) and the highest speeds I can get through Speedtest are around 230mps. I have reset both the Hub 4 and Router a number of times but this makes no difference.
Can someone please advise me if there is anything I do?  Is there anything that can be done centrally by Virgin?
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-7.000000
36.609653
QAM256
1
2
147000000
-7.400002
37.355988
QAM256
2
3
155000000
-7.400002
37.355988
QAM256
3
4
163000000
-7.400002
37.636276
QAM256
4
5
171000000
-7.500000
36.609653
QAM256
5
6
179000000
-7.599998
37.636276
QAM256
6
7
187000000
-7.599998
37.355988
QAM256
7
8
195000000
-7.500000
37.355988
QAM256
8
9
203000000
-7.299999
37.355988
QAM256
9
10
211000000
-7.200001
37.355988
QAM256
10
11
219000000
-7.099998
37.636276
QAM256
11
12
227000000
-7.299999
37.355988
QAM256
12
13
235000000
-7.400002
37.355988
QAM256
13
14
243000000
-7.500000
37.355988
QAM256
14
15
251000000
-7.900002
37.355988
QAM256
15
16
259000000
-7.799999
36.609653
QAM256
16
17
267000000
-8.000000
37.355988
QAM256
17
18
275000000
-8.099998
37.355988
QAM256
18
19
283000000
-8.400002
37.636276
QAM256
19
20
291000000
-8.700001
36.609653
QAM256
20
21
299000000
-8.900002
36.609653
QAM256
21
22
307000000
-8.599998
37.355988
QAM256
22
23
315000000
-8.400002
37.355988
QAM256
23
24
323000000
-7.900002
37.355988
QAM256
24
25
331000000
-7.799999
37.355988
QAM256
25
26
371000000
-7.799999
37.355988
QAM256
26
27
379000000
-7.799999
37.355988
QAM256
27
28
387000000
-8.000000
37.636276
QAM256
28
29
395000000
-8.099998
37.355988
QAM256
29
30
403000000
-8.000000
37.636276
QAM256
30
31
411000000
-8.099998
37.355988
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
0
55
0
2
Locked
89190561
32
0
3
Locked
64183316
2
0
4
Locked
63910026
0
0
5
Locked
63917773
0
0
6
Locked
64128015
0
0
7
Locked
64201651
0
0
8
Locked
25355292
0
0
9
Locked
25556183
0
0
10
Locked
25445907
0
0
11
Locked
25460068
0
0
12
Locked
25080592
0
0
13
Locked
24974635
0
0
14
Locked
25126268
0
0
15
Locked
24904578
0
0
16
Locked
25050134
0
0
17
Locked
25212486
0
0
18
Locked
25037570
0
0
19
Locked
25056641
0
0
20
Locked
25085214
0
0
21
Locked
25079048
0
0
22
Locked
25380360
0
0
23
Locked
25315359
0
0
24
Locked
29261344
0
0
25
Locked
31635067
0
0
26
Locked
31487727
0
0
27
Locked
40323543
0
0
28
Locked
31523627
0
0
29
Locked
31890536
0
0
30
Locked
31704502
0
0
31
Locked
1165330712
0
0
Anonymous
Not applicable
Message 2 of 28
Re: New GIG1 same speed as M500
All of your downstream power levels are out of spec (-6 to +10 is in spec).
Do you have one of these devices connected between the HUB and cable to the wall socket?
pmc815234
  • 26
Message 3 of 28
Yes I do.
Anonymous
Not applicable
Message 4 of 28
@pmc815234 wrote:
Yes I do.
What dB value does it have written on the side?
pmc815234
  • 26
Message 5 of 28
pmc815234
  • 26
Message 6 of 28
6 dB
Anonymous
Not applicable
Message 7 of 28
@pmc815234 wrote:
6 dB
Ok, if you power your HUB off, remove the device, then plug/screw the cable directly into the HUB, and power back on.
This will effectively increase the power level across your downstream channels by 6dB, bringing them in spec.
Once you do this post some fresh stats, including upstream.
pmc815234
  • 26
Message 8 of 28
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
pmc815234
  • 26
Message 9 of 28
3.0 Downstream channels
1139000000-1.29999937.636276QAM2561
2147000000-1.59999837.636276QAM2562
3155000000-1.70000138.605377QAM2563
4163000000-1.70000137.636276QAM2564
5171000000-1.79999937.355988QAM2565
6179000000-1.90000237.355988QAM2566
7187000000-1.90000237.636276QAM2567
8195000000-1.79999937.636276QAM2568
9203000000-1.70000137.355988QAM2569
10211000000-1.40000237.636276QAM25610
11219000000-1.50000038.605377QAM25611
12227000000-1.59999837.636276QAM25612
13235000000-1.59999837.636276QAM25613
14243000000-1.79999938.605377QAM25614
15251000000-2.00000037.636276QAM25615
16259000000-2.09999837.636276QAM25616
17267000000-2.20000137.636276QAM25617
18275000000-2.29999937.636276QAM25618
19283000000-2.70000138.605377QAM25619
20291000000-2.90000237.636276QAM25620
21299000000-3.00000037.636276QAM25621
22307000000-2.79999937.636276QAM25622
23315000000-2.59999837.636276QAM25623
24323000000-2.20000137.636276QAM25624
25331000000-2.00000037.636276QAM25625
26371000000-2.09999838.257755QAM25626
27379000000-2.29999938.605377QAM25627
28387000000-2.29999938.605377QAM25628
29395000000-2.40000238.605377QAM25629
30403000000-2.50000038.605377QAM25630
31411000000-2.70000138.605377QAM25631
1Locked000
2Locked1543259400
3Locked1542890700
4Locked4072177300
5Locked1541021500
6Locked1542897500
7Locked1546110500
8Locked1113876800
9Locked1114227000
10Locked1117330600
11Locked1120563000
12Locked1104915400
13Locked1094554400
14Locked1112716500
15Locked1107189300
16Locked1114855500
17Locked1099883200
18Locked1110078800
19Locked1108017300
20Locked1110641900
21Locked1111613400
22Locked1111973600
23Locked1104924600
24Locked1251458200
25Locked1252856800
26Locked1250683200
27Locked1266565700
28Locked1263282600
29Locked1257960200
30Locked1247568900
31Locked10563891600
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159804K1560QAM1024424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked -1.140661560
pmc815234
  • 26
Message 10 of 28
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13260000034.5205995120 KSym/sec64QAM13
23940000034.0205995120 KSym/sec64QAM12
34620000034.0205995120 KSym/sec64QAM11
45370000034.0205995120 KSym/sec64QAM10
3.0 Upstream channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
