thebigstc
  • 25
Message 1 of 10
Network Speed today 16-12-2020
Hi all
Anyone else noticing massive swings in response times and bandwidth ??
My response time is going from 7ms to 189 ms
My bandwidth is going from 20MB to 550MB
What's going on ??
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Network Speed today 16-12-2020
Try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
thebigstc
  • 25
Message 5 of 10
Hi all
Just run some more tests and it is now running at 8ms and 514 MB down and 30Mb up
thebigstc
  • 25
Message 6 of 10
Ran again after a couple of secs 242 ping response and 24MB down 14MB up
Its so inconsistent there has to be a glitch somewhere NG16 postcode area , virgin media area 30 .
There are no known faults at he moment on the service page
thebigstc
  • 25
Message 7 of 10
Thanks Mike
Will do
thebigstc
  • 25
Message 8 of 10
Just to let everyone know it looks like its settling down
Have had 5ms response and 500MB+ down and 34MB up for the last couple of mins
thebigstc
  • 25
Message 9 of 10
Its been ok for 5 mins now
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 10
Still set up the BQM and post a Live Link then post the Hud data as requested.
