Mathius
  • 28
Message 1 of 16
Network Log and constant loss of connection. Issue
Ok,
For the last few days we've had connections issues, which I thought would have sorted itself after a reboot of the router, but no, so have started to record the network log and the same thing keeps happening.
Spoiler
24/04/2022 12:52:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:47:56 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:45:48 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:43:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:43:26 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:42:56 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:40:3 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:39:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:36:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:23:10 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:23:10 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:22:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:21:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:18:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:18:56 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 12:17:30 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 09:32:18 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 06:40:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2022 04:40:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 17:41:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:55:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:53:43 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:52:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:50:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:49:25 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:47:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:45:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:45:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2022 14:43:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
This is happening far to often for it to be nothing...  and although sometimes a couple of refreshes of the webpage is enough, the point that the connection drops is happening to many times making it frustrating.
Internet speeds are also getting effected...
Spoiler
PING ms
12
 DOWNLOAD Mbps
115.27
 UPLOAD Mbps
0.92
This should be 200 Download and 20 Upload (this is on a wired Cat 6 cable)
Service status in my area reports back normal, but clearly the network log says different...
Any Ideas ?
Andrew-G
  • 11.17K
  • 1.73K
  • 5.34K
Message 2 of 16
Re: Network Log and constant loss of connection. Issue
Network log confirms a very poor connection.  Post the downstream and upstream data from the page where you found the network log, that often shows an easily resolved noise or power fault.
Mathius
  • 28
Message 3 of 16
Downstream (all be it a few hours later)
Spoiler
11390000007.538256 qam1
21470000008.540256 qam2
31550000007.938256 qam3
41630000008.339256 qam4
51710000008.440256 qam5
61790000008.140256 qam6
71870000008.540256 qam7
8195000000840256 qam8
9203000000840256 qam9
102110000007.540256 qam10
112190000007.538256 qam11
122270000007.437256 qam12
132350000007.140256 qam13
142430000007.640256 qam14
15251000000738256 qam15
16259000000738256 qam16
172670000007.640256 qam17
182750000006.538256 qam18
192830000007.138256 qam19
202910000007.538256 qam20
212990000006.438256 qam21
223070000006.938256 qam22
23315000000738256 qam23
243230000005.538256 qam24
1Locked38.943866542176094
2Locked40.9967149245435
3Locked38.93706915726404
4Locked39.341939262158624
5Locked40.352590982069
6Locked40.9459481365
7Locked40.32286533638
8Locked40.3597225120876
9Locked40.331362656835
10Locked40.926771306
11Locked38.9116439347
12Locked37.328908355249
13Locked40.322220652492
14Locked40.948385462
15Locked38.98854179
16Locked38.92202907726
17Locked40.3604987112207
18Locked38.940243446556
19Locked38.9286800
20Locked38.916430
21Locked38.912200
22Locked38.946420
23Locked38.9135910
24Locked38.9655600
Upstream
Spoiler
13259992242.5512064 qam10
24620000044512064 qam8
33940000043.3512064 qam9
45370000044.8512064 qam7
1ATDMA0020
2ATDMA0010
3ATDMA0020
4ATDMA0010
It was actually behaving itself for about 3 hours, and then all of a sudden, another SYNC Timing Failure...
Andrew-G
  • 11.17K
  • 1.73K
  • 5.34K
Message 4 of 16
How long since the hub was last rebooted?  That'll help us tell how quickly the errors are racking up - there's massive post-RS (uncorrectable) error counts on the down stream, that's a sign of a serious noise problem.
Mathius
  • 28
Message 5 of 16
Alright starting to get really annoyed with this now....so much so that I've been looking else where for broadband packages....what good is my 200/20 connection is I cant use the thing.  My money could be better spent on a slower but more stable connection. 😞
@Andrew-G - My hub is normally always on, but whenever I come across connection issues one of the first things I do is, switch off the hub, go make a coffee and then turn it back on.  Sometimes gremlins will be gremlins 😄
Even this morning trying to get back here to check on the replies I've had major issues.
Spoiler
25/04/2022 09:54:37 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:54:16 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:52:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:52:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:50:52 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:49:56 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:49:40 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:49:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:49:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:47:47 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:42:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:40:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:37:37 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:35:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:28:2 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:26:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:24:30 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:22:45 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:16:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:15:19 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:13:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:11:6 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:05:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:04:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:03:40 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 09:02:17 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 08:59:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 08:59:30 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 08:51:58 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 08:50:27 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2022 08:48:8 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mathius
  • 28
Message 6 of 16
Downstream (touch wood for the last 15mins, its up as normal)
Spoiler
11390000007.438256 qam1
21470000008.640256 qam2
31550000007.940256 qam3
41630000008.340256 qam4
61790000008.340256 qam6
81950000008.340256 qam8
92030000008.340256 qam9
102110000007.640256 qam10
112190000007.938256 qam11
122270000007.537256 qam12
132350000007.440256 qam13
14243000000840256 qam14
152510000007.340256 qam15
162590000007.338256 qam16
17267000000840256 qam17
182750000006.940256 qam18
192830000007.538256 qam19
202910000007.940256 qam20
212990000006.840256 qam21
223070000007.338256 qam22
233150000007.538256 qam23
243230000005.938256 qam24
1Locked38.955426943402318
2Locked40.31861081470088
3Locked40.349659971259233
4Locked40.359556423113665
5Locked40.396394283158
6Locked40.3511512293
7Locked40.32607934572
8Locked40.31325392122214
9Locked40.356495957640
10Locked40.3306921083
11Locked38.91230731299
12Locked37.686044357231
13Locked40.374858553433
14Locked40.3504181277
15Locked40.311377320
16Locked38.93295497829
17Locked40.91218919154957
18Locked40.371020646558
19Locked38.92947738
20Locked38.917370
21Locked40.314070
22Locked38.9508864
23Locked38.9136740
24Locked38.9677320
Upstream
Spoiler
13260000043512064 qam10
24620000044.8512064 qam8
33940000044512064 qam9
45370000045.3512064 qam7
1ATDMA0050
2ATDMA0010
3ATDMA0040
4ATDMA0010
Speedtest (as of right now)  200 down / 20 up
Spoiler
PING ms
12
 DOWNLOAD Mbps
68.54
 UPLOAD Mbps
0.23
As you can see, shockingly bad speeds.....
Feeling disappointed with VM at this time.
Mathius
  • 28
Message 7 of 16
------quick update,
Checking the service status, 'We can't see any issues affecting <postcode>'
Following that through, to be able to test the hub and there looks to be an issue after all...
going to try a hub reset for now.
Martin_N
  • 8.87K
  • 371
  • 536
Message 8 of 16
Hi Mathius,
Thank you for your post. I'm very sorry to hear about the issue you've been having with your broadband service.
I have taken a look on our system and it is detecting a short term connectivity issue.
At this point in time we advise to monitor the connection for 24 hours.
^Martin
Mathius
  • 28
Message 9 of 16
Thank you,
I've been monitoring this for the last 4 days now and still getting SYNC Timing failures, RCS partial service.. basically no change, it seems stable for a while and then I'll notice a drop in connection and check my logs to see that its been doing it for hours.
Chris_W1
  • 6.57K
  • 275
  • 440
Message 10 of 16
Hi Mathius, thanks for the message. I can see that you were advised to do a pin hole reset has things improved since this was done? Can you do a broadband quality monitor and send us the results? ^Chris
