MillieGreen20
  • 8
Message 1 of 14
Network Connection and Speed Issues
Could someone let me know what's going on here? The connection often drops which makes conference calls almost impossible.
Downstream:
14750000009.137256 qam9
24110000008.437256 qam1
34190000008.437256 qam2
44270000008.537256 qam3
54350000008.937256 qam4
64430000008.837256 qam5
74510000008.837256 qam6
84590000008.837256 qam7
9467000000937256 qam8
104830000009.537256 qam10
114910000009.537256 qam11
124990000009.437256 qam12
135070000009.537256 qam13
145150000009.537256 qam14
155230000009.937256 qam15
165310000001037256 qam16
175390000001037256 qam17
185470000009.537256 qam18
195550000009.937256 qam19
205630000009.637256 qam20
215710000009.837256 qam21
225790000009.536256 qam22
235870000009.536256 qam23
245950000009.536256 qam24
Upstream:
1461999654.525512064 qam1
2257999914.4512064 qam4
3326000444.425512064 qam3
4394000764.45512064 qam2
Network log:
29/09/2020 11:04:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 17:41:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 08:54:14ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 23:49:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 23:28:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 14:44:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2020 03:43:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 23:21:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 10:09:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 03:21:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 03:30:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 00:49:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 04:20:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:23:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:11:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 08:41:3ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2020 02:03:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2020 01:26:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 ^ the site won't let me post this properly because it's apparently invalid HTML
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Network Connection and Speed Issues
Can you post the second tables from the Downstream and Upstream tabs please.
Then
MillieGreen20
  • 8
Message 3 of 14
Thanks Mike. I'll get the BQM set up and send over a link in a couple of hours
Second downstream:
1Locked37.38149364
2Locked37.38867844
3Locked37.388051092
4Locked37.384481153
5Locked37.68531316
6Locked37.38406309
7Locked37.38133535
8Locked37.37955921
9Locked37.68097705
10Locked37.67463160
11Locked37.37425262
12Locked37.37024541
13Locked37.37154697
14Locked37.369351162
15Locked37.66679136
16Locked37.3650960
17Locked37.36504216
18Locked37.36491498
19Locked37.36659573
20Locked37.36368455
21Locked37.3615469
22Locked36.6637089
23Locked36.36326362
24Locked36.36326642
Second upstream:
3ATDMA0000
4ATDMA0000
MillieGreen20
  • 8
Message 4 of 14
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 14
Can you double check that the WAN IP of your connection is the same as the IP that the BQM is pinging.
It looks almost perfect at the moment and VM BQMs never look that good.
[img]https://i.ibb.co/t4xgVL2/Uni-BB.png[/img]
MillieGreen20
  • 8
Message 6 of 14
Hi Mike
Sorry about that - forgot to turn my VPN off. That should be correct now.
Just in case, here's the link again: My BQM Graph
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 14
@MillieGreen20 wrote:
Hi Mike
That is exactly the same BQM.
MillieGreen20
  • 8
Message 8 of 14
Hi again
Just changed the ip address on the graph and I can see a different trend in the graph coming through.
Best wishes
Millie
MillieGreen20
  • 8
Message 9 of 14
Hi there, just wanted to check back in and see if you had any ideas as far as our wifi issues.
My BQM Graph
Best wishes
Millie
Emily_G
  • 4.82K
  • 209
  • 286
Message 10 of 14
Thanks for the post Milliegreen20.
How are your services since your recent update?
Let us know, Emily.
