spiky64
  • 8
Message 1 of 18
Need help with very low upload speed on M200 broadband
I'm looking for advice on how to improve the upload speed on our M200 service. As advised by VM, I tried to paste the downstream, upstream & network logs I copied from our Hub 3 into this message, but I get an error message telling me my message cannot exceed 20 000 characters. This is really frustrating, as I checked the text in Word, and it says I have <5000 characters. Not sure how I can include my logs - any advice on that would be much appreciated! The download speed seems fine (fairly consistently >200Mbit/s via Ethernet cable), but upload rarely exceeds 3-4Mbit/s.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 18
Re: Need help with very low upload speed on M200 broadband
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 18
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 18
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Andrew-G
  • 8.18K
  • 1.36K
  • 3.7K
Message 5 of 18
Post the data in three separate posts.  There is a character limit per post, I don't believe that it is anywhere near 20,000 characters, but as with some other VM Forum error messages, this one appears to be inaccurate and confusing.
spiky64
  • 8
Message 6 of 18
Thanks very much for your replies - oddly enough when I checked the speed just now using SamKnows it reports a much better upload speed (~17Mbit/s), even without disconnecting all other devices (which could be tricky with 5 broadband users in the house!). I'll keep an eye on things - will try the Broadband Quality Monitor (BQM) suggestion if (when!) things deteriorate again ...
spiky64
  • 8
Message 7 of 18
113900000015.138256 qam1
214700000014.538256 qam2
315500000014.438256 qam3
416300000014.138256 qam4
517100000013.938256 qam5
617900000013.438256 qam6
718700000013.338256 qam7
819500000012.938256 qam8
920300000012.438256 qam9
1021100000011.838256 qam10
1121900000011.138256 qam11
1222700000010.938256 qam12
1323500000010.338256 qam13
142430000009.438256 qam14
152510000008.538256 qam15
16259000000837256 qam16
172670000008.437256 qam17
182750000001038256 qam18
1928300000011.538256 qam19
2029100000012.438256 qam20
2129900000012.838256 qam21
2230700000012.938256 qam22
233150000001338256 qam23
2432300000013.140256 qam24
1Locked38.9125208059
2Locked38.9131878515
3Locked38.9139808708
4Locked38.9242378315
5Locked38.9280087939
6Locked38.9301768671
7Locked38.9260879144
8Locked38.9310189403
9Locked38.6363049450
10Locked38.94676815318
11Locked38.66203115192
12Locked38.68975415229
13Locked38.612097116363
14Locked38.618741415674
15Locked38.631462415750
16Locked37.659576515581
17Locked37.680537715633
18Locked38.625631314591
19Locked38.97431714229
20Locked38.95340713131
21Locked38.65078912421
22Locked38.93917912625
23Locked38.93656112189
24Locked40.33144212546
spiky64
  • 8
Message 8 of 18
14620000043.5512064 qam3
23940000043512064 qam4
36030000044.3512064 qam1
45370000044.3512064 qam2
2ATDMA0010
3ATDMA0010
4ATDMA0010
spiky64
  • 8
Message 9 of 18
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID1602814
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1602813
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 18
Most of your Downstream Power Levels are far too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
