Dannyboi2301
Need and engineer
Im having intermittent problems with my internet and have been trying to contact virgin about getting an engineer out but cannot get through at all
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Need and engineer
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Dannyboi2301
I cant do this. As i dont have a computer just a console. I just need an engineer to come out.
