jjamknight
  • 19
Message 1 of 7
Need a steer on what to do next
We have some issues in the area, and in all fairness I'm very happy with the level of support given from Virgin, They reacted quickly and within a couple of hours we had a Virgin maintenance team on the road investigating (outstanding service)
and we are back up and running, albeit at a slower connection. We normally see +550mb. The speed over the last 24hrs not greater then 90mb.
There was a second issue reported on the network and virgin and that was resolved this afternoon, during that issue we did see intermittent packet loss and increased latency (200ms+) that seems to have now improved but the speed hasn't.
After area network issues do Virgin throttle back bandwidth to get people back up and running and then increase the bandwidth? or should i raise this with virgin as we are not getting the bandwidth.
I think all the hub values are OK (imo) but let me know what you think.
1203000000037256 qam9
2211000000-0.237256 qam10
3219000000-0.537256 qam11
4227000000-138256 qam12
5235000000-1.437256 qam13
6243000000-1.737256 qam14
7251000000-1.537256 qam15
8259000000-1.738256 qam16
9267000000-1.437256 qam17
10275000000-0.737256 qam18
11283000000038256 qam19
12291000000-0.737256 qam20
13299000000-138256 qam21
14307000000-1.238256 qam22
15315000000-138256 qam23
16323000000-138256 qam24
17331000000-138256 qam25
18339000000-0.738256 qam26
19347000000-0.438256 qam27
20355000000-0.938256 qam28
21363000000-1.538256 qam29
22371000000-1.938256 qam30
23379000000-1.738256 qam31
24387000000-1.538256 qam32
1Locked37.6100
2Locked37.6200
3Locked37.680
4Locked38.6150
5Locked37.6190
6Locked37.6160
7Locked37.6240
8Locked38.6120
9Locked37.6100
10Locked37.6100
11Locked38.6120
12Locked37.680
13Locked38.6190
14Locked38.6160
15Locked38.680
16Locked38.6210
17Locked38.6640
18Locked38.680
19Locked38.6220
20Locked38.6210
21Locked38.6100
22Locked38.690
23Locked38.9100
24Locked38.900
15370000044.3512064 qam2
24620000043.5512064 qam3
33940000043.5512064 qam4
46030000044.5512064 qam1
  • 30.68K
  • 3.03K
  • 5.81K
Message 2 of 7
Re: Need a steer on what to do next
BQM not looking good. stats posted look ok - can you also post the Upstream T errors table and also your network logs.
check on   0800 561 0061 whether the issues have been fixed yet
jjamknight
  • 19
Message 3 of 7
Thanks for the reply..
Still no change in speed c70mb, here are the T errors and logs. I would apperciate your thoughts?
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
1
0
Time
Priority
Description
27/08/2021 17:32:24
critical
27/08/2021 09:34:21
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:34:13
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:02:27
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:02:25
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:02:20
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:02:20
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2021 09:02:20
critical
25/08/2021 09:46:36
critical
01/01/1970 02:49:56
notice
24/08/2021 11:34:37
critical
24/08/2021 11:34:35
Warning!
24/08/2021 11:34:30
critical
24/08/2021 11:34:30
Warning!
24/08/2021 11:34:30
critical
24/08/2021 11:34:30
Warning!
22/08/2021 08:22:25
critical
21/08/2021 09:12:44
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/08/2021 07:05:4
critical
updated chart for the last 24hrs, looking a lot better but losing packets
  • 30.68K
  • 3.03K
  • 5.81K
Message 4 of 7
Still showing dropped packets but nothing obvious in the stats to me.
Can you say some more about the connection. Are you in modem mode or normal router mode? What devices have you got connected on ethernet cables?
Speeds hovering just under 100 is always suspicious to me if on an ethernet connection - is that how you are testing?
jjamknight
  • 19
Message 5 of 7
interesting, i hadn't considered that 🙂 Ports (switch) are all at 1gb, however the firewall (ASA) is auto on that interface to the virginmodem (i'll need to look up the commands to dig a little deeper into the actual speed). I also have a patch board so i will check the cabling (i did play around with the virgin modem connection). I have been testing (google speed test and Thinkboardband)  via a PC and iMac off the main switch.
I will reseat cables, check the patch boards and reseat the patch cables and then perform a restart of the Hub and then the ASA. I suspect you are right will find our and confirm in a couple of hours.
Thank you!
jjamknight
  • 19
Message 6 of 7
Bingo, the interface is running at 100mb. I will do the reset and i suspect that will resolve the issue. I will confirm
HomeASA# show interface stat
Interface GigabitEthernet0/0 "outside", is up, line protocol is up
Hardware is i82574L rev00, BW 1000 Mbps, DLY 10 usec
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
Input flow control is unsupported, output flow control is off
Description: HomeWAN
MAC address ecbd.1daf.0d7e, MTU 1500
9202868 packets input, 9988053663 bytes, 0 no buffer
Received 132675 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
4264743 packets output, 1613457422 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 1 interface resets
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops
input queue (blocks free curr/low): hardware (500/451)
output queue (blocks free curr/low): hardware (469/427)
Traffic Statistics for "outside":
9202868 packets input, 9821760028 bytes
4264743 packets output, 1535380835 bytes
22051 packets dropped
1 minute input rate 582 pkts/sec, 480842 bytes/sec
1 minute output rate 258 pkts/sec, 33610 bytes/sec
jjamknight
  • 19
Message 7 of 7
Thank you for your help John. My interfaces to the hub was running at 100mb. A reseating of the patch cables at the patch board corrected the issue and the interface is now up at 1gb. Tested the line speed and back up to 550mb.
HomeASA# show int gigabitEthernet 0/0
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
